Author Topic: Autochart help with older model bird  (Read 8895 times)
Offline kerryd15
  • Unit(s): 798C SI
« on: December 21, 2014, 08:34:58 PM »
Ok so I have a 798 non HD. have been recording and trying to upload to card that is" local"
I made a copy of the original card and have it saved in a separate file.
I changed the name of the LKmaster and AC file on the card per the instructions.
I made an Autochart folder and put a copy of the LKmaster file in that folder. changed the mapping lakemaster setting to use this file to update as the "local card"- that didn't work. So in the Autochart folder with the Lkmaster file I made an "AC" folder. Now when I "update card" there is a LKmaster folder in the AC folder. So when I open the Autochart folder I see the AC and LKmaster. when I open the AC there is another LKmaster folder.- sound correct?
when I started, the 798 with the original unaltered card, the monitor would show lake names and boundaries from the card- selected it from the card slot.
Now I take the LKmaster file from the AC folder which is approximately 2.5GB and copy that to the card. I checked and it is a different size each time I update map with more mapping.
When I put it in my units I get a gray background and all the lake boundaries are gone, no contour lines. I checked setting and lines are supposed to be visible. Any ideas what i'm doing wrong?
I have tried taking the AC/Lkmaster and copying into the Lkmaster, then copy that to the card with no change.
I tried taking the autochart/Lkmaster and copy that into the empty AC folder and updating the card with mapping and the program locks up.
I have tried these with copies of the original card files. Makes sense to me that if the zero lines are in the original Lkmaster folder and you make another AC/lkmaster folder the 2 should be together. worked on this all weekend to no avail. I do have copies of the original that I start with each time. any help appreciated.
Offline omartinjordan
  • Unit(s): 798 CISI
Re: Autochart help with older model bird
« Reply #1 on: December 25, 2014, 11:42:00 PM »
I have the same problem and the same unit you have.   I didn't even get to needing with any maps.   I had a question and called humminbird support and was told that our models do not work with auto chart.   I asked about the work around inductions you are trying and was told that it will not work.   You might want to call them or try and return the program.
Last post January 11, 2011, 10:07:40 AM
Last post March 21, 2012, 10:10:40 AM
Last post January 29, 2013, 10:41:01 AM
Last post January 07, 2014, 11:11:02 AM
Last post March 23, 2014, 02:23:49 PM
by Dieago
Last post October 13, 2014, 02:35:45 PM
Last post December 31, 2014, 09:40:09 AM
Last post May 07, 2015, 11:32:01 AM
