Author Topic: Bird down  (Read 11048 times)
Offline great pappy cat
  • I fish... therefore.. I am
Bird down
« on: January 09, 2011, 01:58:44 AM »
Hello all I had a bad day on the water on the 3rd to the last trip of the season, my prized humminbird 997c went nuts :o?? I made a short video when it happened.
Viddler.com - bird down - Uploaded by jgfishhunter
Can any one tell me what the heck happened?  My unit is 6 months out of warranty
I already contacted customer service and was told it was a $258.95 flat rate to replace. Is it possible to upgrade to a 998c at this point? I spent countless hours putting info on the fishfinder. will all this be lost.  Thank you in advance ...Joe Gunter the Catfish Hunter
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: Bird down
« Reply #1 on: January 09, 2011, 07:06:05 AM »
Hello Joe,
I checked your video. Exactly the same happened to me a couple of times last season and it drove me nuts. I sent it back to JOHNSON OUTDOORS UK and they couldn't find anything wrong with it. Mark suggested to check my electrical installation on the boat.
I found out that a bad battery didn't supply enough power from time to time.
I would suggest you check the wires and the connectors and if the battery provides enough juice to start from as well.
Hope this helps and good luck
Best wishes from Germany
Harry
YES,......
WE SCAN!
Re: Bird down
« Reply #2 on: January 11, 2011, 03:27:39 AM »
Thanks harry ill double check everything before I send it in.
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Bird down
« Reply #3 on: January 11, 2011, 06:44:49 AM »
Joe hook your 997 up to a 12 volt power supply before you send it in.That way
you eliminate batterys or power supply and wire connection problems. Gary
Offline Jolly Roger
  • HB Addicted
Re: Bird down
« Reply #4 on: January 11, 2011, 07:48:24 AM »
Good Point Stillbear!!
I haven't thought about this possibility.
Regards / Harry
YES,......
WE SCAN!
Re: Bird down
« Reply #5 on: January 11, 2011, 10:07:40 AM »
That “power supply” could also be another 12 volt boat battery as well.
If different electrical connections do not help, I would than try loading an older version of software onto the unit.
If you knew someone with the PC Connect cables than you could possibly download the waypoints your unit has on it now.  If you do have to send the unit into Humminbird, the standard procedure is for the Tech to try and download your waypoints first before trying to repair it.  They get loaded back on after any repairs are made or if your unit has to be replaced.  However, there is the chance that this is not always possible so it is wise to always keep an updated copy of your waypoints on your computer.
Last post March 21, 2012, 10:10:40 AM
Last post January 29, 2013, 10:41:01 AM
Last post January 07, 2014, 11:11:02 AM
Last post March 23, 2014, 02:23:49 PM
by Dieago
Last post October 13, 2014, 02:35:45 PM
Last post December 25, 2014, 11:42:00 PM
by omartinjordan
Last post May 07, 2015, 11:32:01 AM
Last post January 11, 2016, 04:08:58 PM
