Author Topic: HumFinder Downloads - SI Target Image(s) Viewer/Tracks/Coverage software  (Read 46120 times)
Offline Timo
  • Unit(s): 798ci SI
  • Software: 4.780
  • Accessories: XHS-9-HDSI-180-T Transducer
Here are the download links to the HumFinder SI Target Image(s) Viewer/Tracks/Coverage software
(Older HumFinder versions v. 1.0.1.1 and  v. 1.0.1.2 (1024x768) are no longer available.)
http://sideimagingsoft.com/downloads/HumFinder/HumFinder_2.0.exe
(for at least 1280x768 screen resolution)
http://sideimagingsoft.com/downloads/HumFinder/HumFinder_2.0_(1024x768).exe
(for at least 1024x768 screen resolution)
http://sideimagingsoft.com/downloads/HumFinder/HumFinder_2.0_short_Installation_and_Operating_Guide.pdf
(a brief Installation and Operating .pdf guide)
Please, add bug reports here
http://forums.sideimagingsoft.com/index.php?topic=766.0
New ideas here
http://forums.sideimagingsoft.com/index.php?topic=767.0
and general discussion, comments and questions here
http://forums.sideimagingsoft.com/index.php?topic=1333
Please do not reply on this download topic!
LabView Runtime Engine
HumFinder is programmed with National Instruments LabView programming language which is used extensively in instrumentation and measurement areas. In order to run HumFinder one needs to install LabView Runtime Engine 2009. It can be downloaded from
http://ftp.ni.com/support/labview/windows/runtime/9.0/
Download and run installation program: LVRTE90min.exe
LabView runtime can also be downloaded from
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1406
I recommend installing the LabView Runtime Engine before installing HumFinder. I also recommend using default folders with instalments. (I haven’t tested instalment to other folders).
Test environment
I have tested HumFinder in the following environment:
Windows XP Professional SP2, SP3
Windows Vista Business
Humminbird 798ci SI, firmware 4.510, 4.780
Google Earth v. 5.1.3533.1731
Note:
With Windows Vista and propanly with Windows 7, one needs to give read and write permissions to the file C:\Program Files\HumFinder\HumFinder.ini for the current user. Without write permission an error message is given when exiting and user interface settings are not saved.
There is no help file available at the moment, but short “Tip Script” is shown when user places cursor over a control.
General Information
Default Humminbird Folder and file names must used for the records i.e.
\RECORD\R00xxx.DAT
\RECORD\R00xxx\B002.IDX
\RECORD\R00xxx\B002.SON
\RECORD\R00xxx\B003.IDX
\RECORD\R00xxx\B003.SON
In other case the HumFinder won’t find those recordings.
Position format, longitude and latitude
The following formats can be used:
[+,-]ddd[°].dddddd[N,S]      Degrees
[+,-]ddd[°] mm.mmmm['][N,S,W,E]   Degrees and Minutes
[+,-]ddd mm['] ss.ssss["][N,S,W,E]   Degrees, Minutes and Seconds
Notice correct decimal separator: dot (.) in United States, Canada, Australia etc.  Comma(,) in Europe... According to your PC settings.
Same format can be used in Google maps and Google Earth.
Change history:
HumFinder v. 1.0.0.1
Initial release
HumFinder v. 1.0.1.1,   v. 1.0.1.2 (1024x768)
Changes
Fixes
- Corrected bug, which prevented SI beam coverage area (swath) to be shown in minus (-) longitudes and latitudes.
HumFinder v. 2.0
New Features
- Display user selectable SI images of target area
     - Aspect ratio correction is used (vertical dimensions correlates with horizontal ones, with certain limitations)
     - Independently zoomable SI images
     - SI Images are pannable when zoomed
     - Image windows are resizeable
     - SI image color is user selectable
     - Measuring tool for measuring dimensions, object height estimation
     - Image copying, saving possibilities
Changes
- Search radius extended to 100 000 feet (30 000km). With 3000ft (1000m) and above only SI tracks are shown
- Abort button added to cancel search on time consuming operations
- Automatic comma separated position (Lat, Lon) tracking from clipboard. Can be used for example with HumViewer
- New position formats added
     [+,-]ddd[°].dddddd[N,S,W,E]
- Search speed is optimized (1.5x - 10x as compared to HumFinder v. 1.0 depending on search)
- Real target “hit” point recording time is shown
Bug Fixes
- Lat, Lon controls were multiline types causing erratic operation in if "enter" was pressed while editing values
- Tracks were limited to 25 different types causing error if exceeded, now max. is 125
Known Limitations
- Tested only in very limited environment
   LabView Runtime Engine 2009 (LVRTE90min.exe)
- Cannot handle position formats starting with N,E,S,W
- Target cursor max. number 50, 125 different tracks can be handled. ("Tracks only" mode has 1 different track)
- Google Earth position tracking won't work if HumFinder is maximized by user since "Show in Google Earth” operation.
- Google Earth will occasionally give "installation" messages when opened by HumFinder - these can be cancelled by user.
- If boat speed is very high, position information and SI data don't go apparently "hand in hand" causing shift in "hit" point
Regards,
Timo
« Last Edit: June 07, 2010, 03:43:21 PM by Timo »
Offline whizkids
  • Unit(s): 1199CI HD SI KVD COMBO
  • Software: 6.840
  • Accessories: Ethernet, remote GPS
Can humfinder be deleted?
Last post April 11, 2009, 11:09:32 PM
Last post April 13, 2009, 05:29:04 PM
Last post July 08, 2011, 06:52:46 PM
by SonarTRX
Last post September 16, 2011, 07:00:25 PM
by SonarTRX
Last post January 24, 2013, 11:02:29 AM
Last post May 06, 2013, 04:14:58 PM
Last post July 09, 2013, 04:43:43 AM
by codking2000
Last post December 03, 2013, 10:36:26 PM
