Author Topic: Can't launch HumViewer  (Read 20117 times)
Offline Free2Fish
  • Unit(s): 386 ci, 999 HD SI
« on: September 24, 2014, 03:43:40 PM »
I took my first trip with my 999 HD SI and recorded a short 2 minute run but I've been unable to view it on my PC. I was able to view a snapshot I took with the 999.
I just installed HumViewer and when I try to start it from the installed desktop icon I get the error message " Could not find main class: HumViewer.HumViewer. Program will exit."
I have the latest version of java installed. Any help would be appreciated.
Harry
Offline N9Phil
Re: Can't launch HumViewer
« Reply #1 on: September 26, 2014, 10:09:53 AM »
It seems to me that I ran into that problem a while back and if I remember right, I needed to remove the program and reload it.   If you do a search on this site for Humviewer, there is quite a bunch of info that might help.
Phil
Offline Free2Fish
« Reply #2 on: September 26, 2014, 01:19:10 PM »
Thanks Phil, but that doesn't seem to be my problem. I've uninstalled the program and tried installing it fresh a couple of times with the same result. I've searched the forum about the issue also with no hits.
Problem is still unresolved.
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Software: Latest Versions
« Reply #3 on: October 06, 2014, 10:02:58 PM »
I had problems with HumViewer and my 64bit pc.   I had to go to the folder containint runHumviewer.cmd and create a shortcut.
C:\Program Fles (x86)\HumViewer\runHumViewer.cmd
Offline Free2Fish
« Reply #4 on: October 07, 2014, 10:08:21 AM »
Thanks Jim, but again, that's not the issue. I get the error message described above when I run that file.
Still unable to use HumViewer.  :(
« Reply #5 on: October 07, 2014, 09:41:54 PM »
Have you tried to launch Humviewer from the program files ...??
Start/All Programs/Humviewer/Humviewer
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #6 on: October 07, 2014, 11:01:00 PM »
Free2Fish
      I seem to remember a post that if you were using Internet Explorer to download HumViewer and it doesn't work, try Firefox or Chrome.
      Searched for the post, but couldn't find it. It's free to try.
               Mike
Offline Free2Fish
« Reply #7 on: October 09, 2014, 09:38:52 AM »
Thanks Rickie and Mike, but no go.
I tried coming in from the Start menu but got the same error message. I also don't use IE but rather have used Firefox for years.
I've got to think it's something to do with my Java setup but just can't figure out what. I have Java version 7. update 67 installed. Could it be that it will only run on version 6?
Does the author of the program ever show up on this forum?
Thanks,
Harry
« Reply #8 on: October 09, 2014, 10:50:52 AM »
Thanks,
Harry
I think I'm using a Java version 6...
You can download older versions of Java here ...
http://www.oracle.com/technetwork/java/archive-139210.html
Martin does pop in occassionally ...
(You can try to PM him...if he has email notification setup ...he may get your request)...
« Last Edit: October 09, 2014, 10:55:13 AM by rnvinc »
Offline Free2Fish
« Reply #9 on: October 09, 2014, 11:06:25 AM »
I think I'll pass on trying to install the older version and just hope that Martin does in fact see this post.
In the meantime, I've got Deepview running and I can play around with it a bit.
Thanks for trying to help,
Harry
« Reply #10 on: October 09, 2014, 07:17:24 PM »
I think you can run more than 1 version of Java at a time ...so you wouldn't have to downgrade or uninstall your Java 7 to install version 6...
http://stackoverflow.com/questions/271609/multiple-java-versions-running-concurrently-under-windows
Offline dgoldan
  • Unit(s): 987, 997, 1198
  • Accessories: Humviewer
« Reply #11 on: October 12, 2014, 10:56:05 PM »
It sounds more like a bad registry entry to me.  Uninstall Humviewer.  Then Run CCleaner (Crap Cleaner) www.ccleaner.com.  Run the Registry Cleaner function (second button down on the left).  This should compare installed programs with registry entries and then give you the option to delete (remove) invalid entries.  Delete All.  Then reboot and try to re-install.  This should remove the bad registry entries and start fresh with the new install.
Dan
South Metro Fire Rescue - Dive Team
Boulder Emergency Squad - Dive Team
Metro Dive Rescue
Offline Free2Fish
« Reply #12 on: October 15, 2014, 10:31:02 AM »
Thanks Dan, tried that but results were the same.
Harry
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #13 on: October 15, 2014, 11:03:10 AM »
This is a long shot but it happened to me. I have a add-on program in Firefox that prevented a download of another program because I
had not re-enabled it following some computer maintenance.
             Mike
Offline Free2Fish
« Reply #14 on: October 15, 2014, 11:33:25 AM »
Tried enabling all my add-ons but still the same problem. Thanks for the idea though. :)
Harry
Offline dgoldan
« Reply #15 on: October 15, 2014, 03:19:58 PM »
If you're convinced that Java is the source of the problem, have you tried uninstalling both Java and Humviewer, and then reinstalling Humviewer, letting it install the version that it's packaged with?
Metro Dive Rescue
Last post January 04, 2010, 07:16:47 PM
Last post November 06, 2010, 12:53:12 PM
by Ranchdip
Last post July 01, 2012, 11:29:29 AM
Last post October 01, 2012, 01:54:35 AM
by Irishrover
Last post March 03, 2013, 05:11:28 PM
by Rickard
Last post April 28, 2013, 08:50:59 AM
by Ken L
Last post August 21, 2013, 12:30:19 PM
by anglerscode
Last post November 07, 2013, 06:59:58 AM
by palajam
