Author Topic: Humviewer.  (Read 16658 times)
Offline oldcrappie
  • Robert Davis
  • Unit(s): 998c SI
  • Software: 5.410
Humviewer.
« on: July 01, 2012, 02:40:55 AM »
I need some help.
Here are 2 images taken from HumViewer. As well one as a snapshot.
HumViewer SI Image
I know that I am not moving but why is there a lighted streak alone the left side of the center of the water column? I also get this while I am under way.
HumViewer 2D Image
I cannot get the color that is found in the default 2d image.
I also get many bottom returns, which make this image useless.
Snapshot from unit
This looks is what I see on the unit.
Note: I do get multiple bottom returns in 2d sonar. What can I do in HumViewer and unit to correct this?
2008 Lund Explorer Crappie Edition
75 Mercury Optimax, 9.9 Mercury Pro-Kicker
Humminbird 998c SI
Lowrance LCX 28c HD
Lowrance LMS 520c
Re: Humviewer.
« Reply #1 on: July 01, 2012, 11:29:29 AM »
Not knowing how you have mounted your transducer only makes  us guessd but I would venture a guess that the streak is a reflection from something on your boat bottom or transom area.
Or the transducer is not level.
Bottom returns can be filtered using settings on the unit.
Humviewer color is a bit different than the HB screen..
Humviewer
Started by BrazosRiverTom General Discussion
Last post February 21, 2015, 11:17:06 PM
Last post May 17, 2015, 09:50:10 PM
by Bayou Basser
Last post February 11, 2017, 01:06:15 PM
by Bayou Basser
Last post April 02, 2017, 05:14:41 PM
by rstell47
Last post December 28, 2017, 09:34:29 PM
Last post June 27, 2018, 05:55:06 PM
Last post February 12, 2019, 10:13:38 PM
Last post July 10, 2020, 12:44:01 PM
by navionic
