Author Topic: 899ci HD Si - power issue and solution  (Read 18824 times)
Offline snowman48047
  • Unit(s): 787c2i
  • Software: 6.6 ???
  • Accessories: speed/temp sensor - weather sense
« on: July 30, 2018, 08:15:10 AM »
Turning unit on, the h'bird logo shows for 1 second then the unit shuts off.   I can use spare power cord on separate battery and unit powers up fine and runs simulator mode. I'm thinking either low voltage or bad power/ground connection. Any other things to check? Everything worked fine 3 weeks ago.
« Last Edit: August 06, 2018, 10:06:30 AM by snowman48047 »
Re: 899ci HD Si
« Reply #1 on: July 30, 2018, 10:09:48 PM »
Easiest test is to have the battery load tested (free at most auto parts stores)  ...
Then delve into wiring if the battery checks good  ...
  • Unit(s): 787c2i
  • Software: 6.6 ???
Re: 899ci HD Si - power issue and solution
« Reply #2 on: August 06, 2018, 10:07:35 AM »
battery checked out good - found a splice corroded so bad it fell apart when I unwrapped the tape.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #3 on: August 06, 2018, 04:22:02 PM »
Thank you for sharing the solution to your problem.   Sometimes, after Rickie suggest trouble shooting ideas, we don't hear back on the out come.   Although, if I were to bet, I'd borrow money to bet he is correct.
         Mike
Last post June 15, 2012, 06:37:54 PM
by jsiegle24
Last post February 04, 2013, 07:20:12 PM
by LocDown
Last post September 08, 2013, 09:21:24 AM
by CHOOhonets
Last post September 24, 2014, 06:38:37 AM
by bgump24
Last post January 20, 2015, 11:27:20 PM
Last post April 25, 2015, 09:41:40 PM
by Hennessyt
Last post May 20, 2016, 11:08:29 AM
Last post April 02, 2019, 09:38:42 AM
