Author Topic: 798c HD SI  (Read 7837 times)
Offline nitronut38
  • Quit Wishin' Go Fishin'
    • Get Reeled
  • Unit(s): 997c SI, 798C HD SI
798c HD SI
« on: September 09, 2011, 05:56:17 PM »
I have the new 798c HD SI mounted at the front of my boat with the trolling motor transducer. Everytime I pull up the trolling motor without shutting off my unit, the unit freezes and I have to unplug it from the quick disconect mount and power it back on. Is there something wrong with my unit? or should I just be getting in the habbit of turing the unit off before pulling the trolling motor out of the water?
Quit
Re: 798c HD SI
« Reply #1 on: September 20, 2011, 02:14:28 PM »
You should not have to unplug the unit whenever you pull the trolling motor out of the water.  The unit may not be showing the correct depth but it should not freeze up.  Not sure where the problem would be either, maybe call the Customer Resource folks and see if they have a suggestion.
Just make sure that you have your cables run so that raising your trolling motor is not pulling or tugging on any of the cables for your unit.
Last post February 05, 2013, 12:00:29 PM
Last post September 02, 2013, 07:40:32 PM
by Kokanee
Last post November 14, 2013, 01:44:43 PM
by hgv
Last post October 02, 2014, 06:43:18 PM
Last post April 11, 2016, 10:50:14 PM
Last post February 23, 2017, 08:05:05 PM
Last post May 01, 2017, 02:45:38 PM
by N9Phil
