Author Topic: 1198 picking sd card  (Read 8856 times)
Offline beertech
« on: September 15, 2014, 06:36:11 AM »
where do you go to choose which of the two sd cards you want to be using
Re: 1198 picking sd card
« Reply #1 on: September 15, 2014, 08:17:31 AM »
If you have a map card in the unit ... It should automatically choose the map card for the chart views...
If you have 2 map cards in the unit ...
*Press Menu twice to get into the main tabbed menu ...
*Cursor over to the Chart Tab ...
*Cursor down to "Chart Select" ...
*Choose Left or Right slot ...
If the unit has 2 map cards inserted and the Chart Select menu is set to "Auto" ... I think it defaults to the right card slot ...
The unit can only display data from 1 map card at a time ...
I can't think of any scenario one would want 2 SD Cards (non-map) in the unit at the same time...but the unit can still be "Forced" to use the Left of Right card slot with the sequence above...
« Last Edit: September 15, 2014, 08:20:42 AM by rnvinc »
Offline beertech
« Reply #2 on: September 21, 2014, 03:00:39 PM »
I have one lakemaster card and a navionics card.  It seems to only find the lakemaster no matter which slot its in.  Is that something due to lakemaster being owned by humminbird
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #3 on: September 21, 2014, 09:37:06 PM »
I used to have to manually select the HotMaps USA I had in a Lowrance LMS332c - which had a single card slot - I think it's a Navionics thing, usually the HB software is made for ease of use. If you set the slot to the Navionics you should be fine - but I also have an older HotMaps & the built in Contour XD on my 798ciSI and that card didn't get along to swell - I think the machine thought the data was the same.... and for the most part it was with the exception of Hi Def maps.
I have 2 LakeMaster's now and every once in a while I think of a Navionics, and then I think ....maybe not....lol
« Reply #4 on: September 22, 2014, 12:10:06 PM »
beertech,
Will your unit recognize and use the Navionics map card data if you take the LakeMaster card out and restart the unit?
Offline beertech
« Reply #5 on: September 22, 2014, 08:03:14 PM »
yes it will recognize navionics if i remove lakemaster
« Reply #6 on: September 23, 2014, 09:50:24 AM »
Are you running the latest software in your 1198 unit beertech?
Offline beertech
« Reply #7 on: September 23, 2014, 09:15:31 PM »
i just bought it in june but not sure
Offline sfw1960
« Reply #8 on: September 23, 2014, 09:42:20 PM »
If it was June - I would doubt it.
My 899 was built in Nov. 2013 and I picked that up in April from a seller that's close to the "pipe".
Never know - only 2 ways to find out, status screen or 3rd selection on boot. ;)
« Reply #9 on: September 24, 2014, 11:06:01 AM »
I doubt that you are either beertech.  We stopped making the 1198 units as it was replaced by the 1999 model and the last software release for the 1198 was in May-June of this year.  So unless you or the seller updated the software than you are running an older version.  Try updating the software to see if it helps or not.
Offline beertech
« Reply #10 on: September 24, 2014, 08:55:03 PM »
how do i go about updating. Also my unit shows pallette 1 2 3.  I have read there is a lowrance pallette option is there,
« Reply #11 on: September 25, 2014, 10:43:01 AM »
Last post May 24, 2011, 05:18:28 PM
Last post April 11, 2012, 02:02:57 PM
by slabbandit
Last post April 15, 2013, 12:51:21 PM
Last post September 06, 2013, 09:22:28 AM
by TroyBoy30
Last post April 07, 2014, 01:36:34 PM
Last post April 06, 2014, 02:54:23 PM
by beertech
Last post September 21, 2014, 11:57:33 AM
by prov275
