Author Topic: 999ci HD NOT LOADING MAPS  (Read 7403 times)
Offline DOVO
  • Unit(s): 798ci HD SI; 999ci HD SI; 959ci HD DI
« on: September 01, 2014, 11:03:19 PM »
Greetings,
Finally was able to record some sonar, but somehow I cannot get converted maps onto the unit.  I am using AUTOCHART PRO.  What I did was I copied the "LkMaster" folder from the ZERO LINES SD CARD and made it local on my computer.  Thus, based on the "Getting Started" instructions I am able to create maps and see them on the computer WITHOUT the ZERO LINES CARD plugged into the computer.  I understand that by doing this I will have to MANUALLY copy and paste the converted maps onto the ZERO LINES SD.  Now to the confusing part or what I did.  I copied the "AC" folder with the new generated "LkMaster" folder onto the card and after that plugged the card into the unit and cannot see the generated map.  What am I doing wrong?  Also the 999ci HD has software 6.860 which makes me wonder if I need to update.  Any ideas that can help will be great.  Thank you.
« Last Edit: September 02, 2014, 12:50:15 AM by DOVO »
Re: 999ci HD NOT LOADING MAPS
« Reply #1 on: September 09, 2014, 10:38:26 AM »
Yes, updating the software would be a good place to start since the AutoChart enhancements were not added until after the 6.860 software version.
Last post March 24, 2010, 12:48:18 PM
Last post February 09, 2014, 01:13:24 AM
Last post February 14, 2014, 12:57:39 PM
Last post May 28, 2014, 08:20:10 AM
Last post May 27, 2014, 01:28:23 AM
Last post June 29, 2014, 03:25:36 PM
Last post June 27, 2016, 08:49:01 AM
Last post March 11, 2022, 11:39:22 AM
by Swann
