Author Topic: Wont turn on!  (Read 17571 times)
Offline JD88
  • Unit(s): 598
  • Software: Newest
  • Accessories: None
Wont turn on!
« on: August 22, 2014, 05:42:29 PM »
I've noticed last few trips the unit keeps shutting off on me and I figured I had a bad wire. Checked the wires and they were fine. Run power through a fuse as recommended and unit has always been babied. Only time it's on the boat is when it's in the water. Checked power at the battery 8.45v and at the unit power plug 8.45v..... Just tried calling and of course they closed up the minute I called. Anybody know of a fix or just have to send it in?
Re: Wont turn on!
« Reply #1 on: August 22, 2014, 07:08:46 PM »
Is 8.45v a typo...??
That's way too low for the units...the manual says the unit needs 10-20v...
Can you have your battery load tested...?? (Auto parts stores will test this free)...
Offline JD88
  • Unit(s): 598
  • Software: Newest
  • Accessories: None
Re: Wont turn on!
« Reply #2 on: August 24, 2014, 01:52:53 PM »
I didn't think my battery was that low but it could be. I'll try it again after charged before calling. I could have had the multi meter set wrong I don't know but does show that I was getting power to the plug. Thanks
Offline JD88
  • Unit(s): 598
  • Software: Newest
  • Accessories: None
Re: Wont turn on!
« Reply #3 on: August 25, 2014, 01:15:34 PM »
Apparently my battery was that low. Thanks!
Re: Wont turn on!
« Reply #4 on: August 25, 2014, 02:22:19 PM »
It could be damaged as well.  I would get it load tested so that you don't get stranded out on the water sometime.
Last post June 15, 2012, 06:37:54 PM
by jsiegle24
Last post April 17, 2013, 10:28:15 PM
by albe
Last post January 28, 2013, 06:18:05 PM
Last post March 23, 2014, 10:52:56 AM
by chuck41
Last post September 03, 2014, 03:09:29 PM
by Calcoast
Last post November 23, 2016, 10:30:11 PM
by rickmbp
Last post September 16, 2018, 08:01:56 AM
Last post August 12, 2019, 11:55:10 PM
by Jamykid
