Author Topic: Best Shallow water settings?  (Read 11216 times)
Offline ArtTricks
  • Unit(s): 899SI, 859DI
« on: August 22, 2014, 11:47:02 AM »
Hey guys Ive got a 899 SI at the console and a 859 ci HD DI and the trolling motor. I'm using the original color palet and when i'm fishing in about 12ft a rock bottom would show red on the sonar while the same bottom in 3-4ft will show yellow, is there a better set of settings that i could use the find rocks in the shallows?
BTW Eyes arent an options since i have about 3-4 inches visibility where i fish!
Thanks folks!
Offline sfw1960
  • Bringer Of The 'Bird
Re: Best Shallow water settings?
« Reply #1 on: August 22, 2014, 12:17:22 PM »
I like palette #3 IIRC....
Cursor>>>> all the way right & report back.
« Reply #2 on: August 25, 2014, 01:34:33 PM »
Since you have the 899 Si unit you could use the Green/Red SI Colors menu setting and spot the rocks using your Si sonar.  They should really stand out against a soft bottom.
Last post November 13, 2010, 01:37:35 AM
Last post February 17, 2011, 05:49:06 PM
Last post March 17, 2011, 01:51:12 PM
by xSilmarilSx
Last post January 11, 2012, 12:09:30 AM
by mmarcum6
Last post April 21, 2012, 08:34:43 PM
by Fay
Last post December 20, 2012, 01:53:44 PM
by Fay
Last post September 12, 2014, 01:35:50 AM
by Fwishynz
Last post October 12, 2018, 09:12:21 AM
by GM
