Author Topic: Most accurate shallow water settings???  (Read 17794 times)
Offline 96720
  • Unit(s): 998c si
  • Software: v5.410
« on: March 17, 2011, 01:18:59 PM »
What is the minimum "accurate" depth reading possible from a 998c si?  And, what would be the most accurate frequency and settings for depth soundings from 20 feet to 2 feet?  It will be in brackish water with a range in salinity of 1.0 to 24 ppt.  Thanks again for your help.
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: Most accurate shallow water settings???
« Reply #1 on: March 17, 2011, 01:51:12 PM »
For accurate readings, I use these settings.
200 kHz only between 0-10ft
surface clutter between 6-10
Fixed range to 10ft, in 0-10ft situation
Switchfire Clear Mode
I have reliable depth readings up to 1.5ft
Last post November 13, 2010, 01:37:35 AM
Last post February 17, 2011, 05:49:06 PM
Last post March 16, 2011, 03:20:24 PM
by TazzMan
Last post April 28, 2011, 03:24:49 AM
by xSilmarilSx
Last post July 26, 2011, 11:21:37 AM
Last post April 21, 2012, 08:34:43 PM
by Fay
Last post August 25, 2014, 01:34:33 PM
Last post October 12, 2018, 09:12:21 AM
by GM
