Author Topic: SI layer ...contour mode?  (Read 13817 times)
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
  • Accessories: autochart pro, ipilot
« on: August 14, 2014, 11:46:55 AM »
I am begining to create a SI layer for my lakemaster autochart map.  Was looking at first few recordings and realized that the normal recording is really not useful for the SI layer.  It would seem that creating recordings in contour mode would be more useful and provide a better background layer to the lakemaster chart.  Hopefully, the contour mode recordings do not lose the data in the cone angle under the boat but rather combine the data in both sides to create a bottom image for the area in the cone.  Does anyone know if this is true or how it actually works??
Re: SI layer ...contour mode?
« Reply #1 on: August 14, 2014, 01:03:29 PM »
I have not tried this myself but would expect to get the same results whether the Contour Mode was on or off.  The Sonar Recordings are a copy of the raw data so any menu settings in the unit will not affect it, so the data going to AutoChart would be the same.  Good idea though mmikos and I’m hoping that I’m wrong…
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #2 on: August 15, 2014, 10:52:37 AM »
Greg
You are so right.  The contour mode recording does not retain its image when imported into autochart.  it stays in the normal (raw).  It would be so much more useful as an autochart layer if it could be in contour mode.  In fact, i would almost think that this is a bug(fault) of autochart. as the use of the SI information as a layer in the program really does not want the down image portion of the recording other than the pure bottom information.  for example, this morning i ran over an old bridge base in our lake and took some snapshots and recordings.
below is a snapshot of the bridge base in normal SI mode
next i took a run over the same area using contour mode
I then recorded the same information in contour mode and imported into autochart
the autochart program played the recording back in normal (raw) mode.
it would have been so much more useful, if i had not lost the 100 or so feet of bottom not shown. It would have provided a seamless image for this layer of the map.  I would think that this would have been what the developers were trying to achieve.
Perhaps a change request to the developers could incorporate the algorythm used to create the contour mode image into the autochart program.
thanks for your response
mmikos
Modify message
Offline D S
  • Software: 7.5
« Reply #3 on: August 15, 2014, 11:09:17 AM »
if u go into SI settings in AC .... i believe u can use slant range correction ?? or something to get rid of water column
....at work will check later
ds
stgr
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #4 on: August 15, 2014, 12:02:10 PM »
dave
thanks for the help
I had slant range correction checked and this is the results i got
without slant range checked.  the results are even worse
so i guess the slant range works (sort of) or at least partially
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #5 on: August 15, 2014, 12:03:07 PM »
perhaps it is a matter of depth...these shots were taken at 54 foot of depth.
Offline D S
  • Software: 7.5
« Reply #6 on: August 15, 2014, 12:59:09 PM »
looks like top image has water column removed but not second pic?
stgr
Offline Rotus623
  • Software: 6.49
« Reply #7 on: August 16, 2014, 02:11:17 AM »
So am I hearing this right we can now layer our SI data into a chart format, like lowrances structurescan overlay?
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #8 on: August 16, 2014, 08:38:54 AM »
Yes.. the PRO version of the software has the ability to create a SI layer
Last post May 14, 2010, 10:08:45 AM
Last post August 14, 2010, 11:24:01 PM
Last post March 11, 2012, 07:11:38 PM
Last post May 17, 2012, 07:48:39 PM
by Prdbrissy
Last post August 11, 2012, 11:59:27 AM
by Roddy
Last post December 04, 2014, 07:24:52 AM
by Koen Vandecauter
Last post April 16, 2015, 05:16:38 PM
by CamoHunter
Last post August 16, 2017, 09:16:41 PM
