Author Topic: Humviewer Debug  (Read 13157 times)
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
Humviewer Debug
« on: February 21, 2010, 11:54:53 PM »
Here is an error list that Iam getting with Humviewer.  Can anyone help.
2010-02-21 23:50:24,469 INFO  [AWT-EventQueue-0] HumViewer.Model.DATDataProvider - Recording start =<1213461124>, =<14/06/2008 12:32:04 EDT>, RecName =<R00067>, extension =<.SON>
MM lat/lon =<2944772, -8930658> lat, long =<25.710471078930468, -80.22230878315096> =<25º 42.628N, 80º 13.339W>, numRecords =<2196>, RecLenMs =<197038>, sizePerLine =<1701>
2010-02-21 23:50:24,516 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B000.idx> contains data for 197 seconds in 549 records. Read in 31 millis
2010-02-21 23:50:24,594 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<0>, Freq =<83000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<197>, Data currently loaded =<0>
2010-02-21 23:50:24,625 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B001.idx> contains data for 198 seconds in 549 records. Read in 15 millis
2010-02-21 23:50:24,688 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<1>, Freq =<200000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<198>, Data currently loaded =<0>
2010-02-21 23:50:24,719 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B002.idx> contains data for 197 seconds in 549 records. Read in 16 millis
2010-02-21 23:50:24,797 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<2>, Freq =<462000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<197>, Data currently loaded =<0>
2010-02-21 23:50:24,828 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B003.idx> contains data for 197 seconds in 549 records. Read in 15 millis
2010-02-21 23:50:24,906 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<3>, Freq =<462000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<197>, Data currently loaded =<0>
2010-02-21 23:50:42,500 ERROR [Thread-3] HumViewer.View.HumView - Exception caught in shutdown hook:
java.lang.NullPointerException
   at HumViewer.ctrl.Configuration.makeWaypoints(Configuration.java:222)
   at HumViewer.ctrl.Configuration.saveConfiguration(Configuration.java:108)
   at HumViewer.View.HumView$1.run(HumView.java:108)
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
  • Accessories: Speed sensor
Re: Humviewer Debug
« Reply #1 on: February 22, 2010, 02:59:01 AM »
Hi Carl
I will take a look at it tonight when I get home from work.
/Martin
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
Re: Humviewer Debug
« Reply #2 on: February 22, 2010, 07:44:00 AM »
Thanks.  One other note.  I can run my files through humviewer 3.031 and then close them and then open them again in version 60 and everything works fine.  I ve also noticed that the xml doc is missing the waypoint information at the bottom when it's not working and its included when it is working.
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
Re: Humviewer Debug
« Reply #3 on: February 22, 2010, 08:22:33 AM »
Hi Carl
Yep, that sound like the problem. I had almost forgot that I changed the way that the waypoints is saved in .xml file. So if you have a .xml file from version 3.031 without any waypoints, then you will get the problem.
I will fix the problem, and release a new version within the next few days.
/Martin
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
Re: Humviewer Debug
« Reply #4 on: February 22, 2010, 04:19:44 PM »
Thanks.  I will be waiting for the new version and just to let you know I really like the program and the changes you made to it.
Last post June 26, 2012, 12:42:19 PM
by Weekend Warrior
Last post August 05, 2012, 09:35:36 AM
by SpineyNole
Last post March 03, 2013, 05:11:28 PM
by Rickard
Last post March 15, 2013, 02:23:06 PM
by nicko_cairns
Last post March 31, 2013, 07:58:16 AM
by Rüdiger
Last post April 28, 2013, 08:50:59 AM
by Ken L
Last post August 21, 2013, 12:30:19 PM
by anglerscode
Last post November 07, 2013, 06:59:58 AM
by palajam
