Software and Software Development => Other 3rd Party Software => HumViewer => Topic started by: Carl on February 21, 2010, 11:54:53 PM
Title: Humviewer Debug
Post by: Carl on February 21, 2010, 11:54:53 PM
Here is an error list that Iam getting with Humviewer.  Can anyone help.
2010-02-21 23:50:24,469 INFO  [AWT-EventQueue-0] HumViewer.Model.DATDataProvider - Recording start =<1213461124>, =<14/06/2008 12:32:04 EDT>, RecName =<R00067>, extension =<.SON>
MM lat/lon =<2944772, -8930658> lat, long =<25.710471078930468, -80.22230878315096> =<25 42.628N, 80 13.339W>, numRecords =<2196>, RecLenMs =<197038>, sizePerLine =<1701>
2010-02-21 23:50:24,516 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B000.idx> contains data for 197 seconds in 549 records. Read in 31 millis
2010-02-21 23:50:24,594 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<0>, Freq =<83000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<197>, Data currently loaded =<0>
2010-02-21 23:50:24,625 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B001.idx> contains data for 198 seconds in 549 records. Read in 15 millis
2010-02-21 23:50:24,688 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<1>, Freq =<200000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<198>, Data currently loaded =<0>
2010-02-21 23:50:24,719 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B002.idx> contains data for 197 seconds in 549 records. Read in 16 millis
2010-02-21 23:50:24,797 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<2>, Freq =<462000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<197>, Data currently loaded =<0>
2010-02-21 23:50:24,828 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Index file =<C:\Documents and Settings\Carl Lackey\Desktop\test\RECORD\R00067\B003.idx> contains data for 197 seconds in 549 records. Read in 15 millis
2010-02-21 23:50:24,906 INFO  [AWT-EventQueue-0] HumViewer.Model.SONDataProvider - Beam =<3>, Freq =<462000>, HasDepth =<true>, NumRecords =<549>, NumSeconds =<197>, Data currently loaded =<0>
2010-02-21 23:50:42,500 ERROR [Thread-3] HumViewer.View.HumView - Exception caught in shutdown hook:
java.lang.NullPointerException
   at HumViewer.ctrl.Configuration.makeWaypoints(Configuration.java:222)
   at HumViewer.ctrl.Configuration.saveConfiguration(Configuration.java:108)
   at HumViewer.View.HumView$1.run(HumView.java:108)
Title: Re: Humviewer Debug
Post by: mrj9600 on February 22, 2010, 02:59:01 AM
Hi Carl
I will take a look at it tonight when I get home from work.
/Martin
Post by: Carl on February 22, 2010, 07:44:00 AM
Thanks.  One other note.  I can run my files through humviewer 3.031 and then close them and then open them again in version 60 and everything works fine.  I ve also noticed that the xml doc is missing the waypoint information at the bottom when it's not working and its included when it is working.
Post by: mrj9600 on February 22, 2010, 08:22:33 AM
Hi Carl
Yep, that sound like the problem. I had almost forgot that I changed the way that the waypoints is saved in .xml file. So if you have a .xml file from version 3.031 without any waypoints, then you will get the problem.
I will fix the problem, and release a new version within the next few days.
/Martin
Post by: Carl on February 22, 2010, 04:19:44 PM
Thanks.  I will be waiting for the new version and just to let you know I really like the program and the changes you made to it.
