Author Topic: 1198 temperature readout  (Read 11729 times)
Offline ntfisherman
  • Unit(s): 898c si & 1198c si
« on: June 16, 2014, 03:42:52 AM »
Hi there. Is anyone had issues with an incorrect temperature readout on their 1198 unit. Just recently I am getting readouts that are 40 or more degrees out. For example when it might be 76 in the water I have had readouts from 3 to 40 throughout the day. There does not appear to be any damage around the transducer. Everything else is functioning as expected.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: 1198 temperature readout
« Reply #1 on: June 16, 2014, 08:57:10 AM »
More than likely a poor conncetion or the sensor in the transducer gone bad. Cheap and quick to clean the pins. Bob
« Reply #2 on: June 16, 2014, 11:00:06 AM »
Have you changed software versions lately to cause this issue to show up...??
In addition to Bob's suggestion...you can Restore Factory Defaults and test again...
Offline ntfisherman
« Reply #3 on: June 16, 2014, 05:20:22 PM »
Thanks for the suggestions. I will try cleaning the pins as I had not thought of that. I do tow the boat over some very dusty roads. I haven't done a software upgrade for some time so I do not think that is the problem. I do have another new transducer unit to put on if all fails. I am still using the transducer off the older 898c si so that may have started to fail through age and perhaps minor damage.  I will let people know what I find. thanks.
Offline bobcoy
« Reply #4 on: June 16, 2014, 06:00:30 PM »
plug your spare transducer in and hang it over the side. You will know right away if it is the transducer.
« Reply #5 on: June 16, 2014, 07:59:35 PM »
I think the temp sensor can be tested in Normal or Simulator while the boat is not on the water...
The readout should show the ambient temp...
You can put yor finger on the temp probe and watch the temp readout climb from your finger's body heat...
« Last Edit: June 16, 2014, 08:01:01 PM by rnvinc »
Offline susieq
  • Unit(s): 1197c
  • Software: 6.2
  • Accessories: no
Offline ntfisherman
« Reply #7 on: July 14, 2014, 09:41:34 AM »
I replaced the transducer and the problem is fixed. There was some slight tearing of the flexible joint of the cable as it entered the transducer pod. I am assuming that water has entered or something else was damaged.
Last post April 29, 2010, 11:49:15 PM
Last post April 14, 2011, 03:59:36 PM
Last post March 16, 2012, 04:55:55 PM
by Fay
Last post March 02, 2016, 02:12:12 AM
Last post August 06, 2013, 08:05:18 PM
Last post March 29, 2014, 02:11:42 PM
by Saltykayak
Last post March 15, 2015, 09:54:24 PM
by ckd022
Last post April 26, 2017, 04:51:08 PM
