Author Topic: can i move readout display on 998  (Read 12242 times)
Offline jimmythegreek
  • Unit(s): 998c SI, 958cHD DI, 596HD, 595cGPS, 565
« on: October 28, 2012, 03:09:13 PM »
Is there anyway to move, shrink, or change the left side bar display on my 998c SI?  It makes the screen so much smaller especially when using split screen views.  Makes me regret not getting the 1198.......thanks for any help......
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: can i move readout display on 998
« Reply #1 on: October 28, 2012, 08:38:21 PM »
turn big numbers off
« Reply #2 on: October 29, 2012, 10:56:01 AM »
There is nothing that you can do in the split screens to shrink this area.
While in the full Si View you can go into the Sonar menu tab and set the “SI Readouts” menu to the “Off” setting.
Offline Justins
  • Unit(s): 597 998si
« Reply #3 on: November 04, 2012, 06:45:43 AM »
Thanks for the question and answer I just learnt something. Sweet
Offline Sigler
  • Unit(s): 1198c 788ci di
  • Accessories: interlink
« Reply #4 on: November 07, 2012, 09:28:07 PM »
How do you remove the readout COG that appears on the left hand side?
« Reply #5 on: November 08, 2012, 09:11:59 AM »
That depends on which unit you are talking about, the software version in it and – more importantly – which View you are using and whether you are using the GOTO function or not.  You can go into the Select readouts menu and set that digital readout location to display something else (or nothing).  If it is not showing as being selected in the Select Readouts menu, than it is being displayed by default according to the View you are using and if you are using the GOTO function (travelling to a waypoint).  If this is the case than it could only be changed by a change to the unit’s software.
Offline southern45
« Reply #6 on: February 29, 2016, 10:13:59 PM »
  I am having same problem with cog  and xte i can not get it to go away i changed settings and when i use map it changes and i can no longer see any depth or speed or temp readings i have current software updates  and running 999 .. had unit for year and just started some times it changes when just using sonar  is very annoying i need depth info ect  what can i do?? i tried factory default no good.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #7 on: March 01, 2016, 10:33:39 AM »
Under the setup tab there are 2 different readout tabs. One for Navigation and the other for other functions. There are some items in the navigation tab that cannot be removed. Bob
« Reply #8 on: March 02, 2016, 02:12:12 AM »
Here is the info I have on which readout boxes can be changed on certain views ...
800/900 Readouts
NAVIGATION:
1-Customize
2-Fixed: Heading
3-Fixed: Bearing
4-Fixed: Split: Cross Track Error(XTE) and Distance To Go (DTG)
5-Fixed: Split: Time To Go (TTG) and Speed
CHART:
1-Customize
2-Fixed: Heading
3-Fixed: Customize
4-Customize
5-Fixed: Speed
BIRDS EYE VIEW:
1-4 Fixed with Depth, Heading, Position, Speed
5-customize
SONAR VIEWS:
1-5 Customize
Last post April 29, 2010, 11:49:15 PM
Last post March 06, 2011, 04:06:53 PM
by bryanmc
Last post April 14, 2011, 03:59:36 PM
Last post March 16, 2012, 04:55:55 PM
by Fay
Last post June 17, 2013, 10:13:24 AM
by Wackyracer
Last post May 14, 2013, 05:50:23 PM
Last post March 29, 2014, 02:11:42 PM
by Saltykayak
Last post March 02, 2015, 04:06:53 PM
