Author Topic: 898c not showing displays  (Read 15257 times)
Offline Curry87
« on: June 06, 2014, 10:57:30 AM »
I have a 898c on the front of my boat interlinked with a 1198 at console. For some reason it's not pulling my maps up or the time of day. I checked connections all good an restarted my participation with my interlink an it's still not workin. I went to readout selections an it's not even giving me the options. Any help would b great thanks
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: 898c not showing displays
« Reply #1 on: June 06, 2014, 12:10:56 PM »
Do you have interlink or ethernet?
Offline Curry87
« Reply #2 on: June 06, 2014, 12:49:55 PM »
I have interlink. I tried default settings an still nothing.
Offline bobcoy
« Reply #3 on: June 08, 2014, 08:59:44 AM »
I am not familiar with interlink but if you disconnect from the box do your units run correctly? Bob
Offline Curry87
« Reply #4 on: June 09, 2014, 07:52:16 AM »
I tried unplugging interlink an nothing changed. I also moved it to the console an nothing changed there also so I guess I will call customer support an see if they have any idea what it could be.
« Reply #5 on: June 09, 2014, 03:46:08 PM »
How do you have a GPS Receiver connected to your 898 and 1198 units with the InterLink Curry87?
Offline Curry87
« Reply #6 on: June 09, 2014, 05:05:50 PM »
I'm not really electronic savvy with the units I bought the boat last year from someone. An everything has worked up until last weekend on the water an it just up an quit. But everything works fine with my 1198 at the console.
« Reply #7 on: June 10, 2014, 10:27:06 AM »
How many GPS Receivers do you have on your boat?
Trace the wire from them and see what it plugs into.  This is so we can tell whether the problem is in the unit, a GPS Receiver or possibly in the InterLink.
Can you contact the prior boat owner for assistance with this?
Offline Curry87
« Reply #8 on: June 10, 2014, 02:13:28 PM »
I only have one gps puck hooked up to the boat. I can trace wire an check connections. An will also check with the previous owner. I have a extra puck I can plug in an eliminate the one to see if that may b. thanks
Offline Curry87
« Reply #9 on: June 10, 2014, 05:19:31 PM »
I changed my gps pucks an I get nothing different. I did put 898 at the console an put 1198 at the front an I get half the options now on 1198 an all options on the 898. So I don't believe it's the unit nor the gps puck so that leaves me to believe its the interlink does this sounds right?
Offline NickO
  • Unit(s): 898c SI, 998CI HD SI
  • Software: 6.740, 6.740
  • Accessories: Ethernet
« Reply #10 on: June 10, 2014, 06:39:37 PM »
what are the voltage readouts on each unit?
Gee that broke easy.
Offline Curry87
« Reply #11 on: June 10, 2014, 07:04:01 PM »
I'm gettin like 13.4 on my voltage read out. Im thinkin it's either the interlink box went out or I nicked a wire when the lake was real rough. Think I'm just gonna solve the problem with a Ethernet cord
Offline bobcoy
« Reply #12 on: June 10, 2014, 07:27:12 PM »
That is with the charger on I bet. Ethernet and current updates for the units will be your best bet. If battery is good,and charged you should get 12.4 at the battery. 12.2 at the unit if wires are good. Good luck. Bob
Offline Curry87
« Reply #13 on: June 10, 2014, 08:44:08 PM »
Thanks bob. Your right 12.4 an I just bought a new 29 mil this year when I did the unit upgrade.
« Reply #14 on: June 11, 2014, 12:44:57 PM »
It could be a bad InterLink Connection Cable too.  Try swapping which cable is plugged into which port on the InterLink and see what changes on the units.  If the cable is the problem the problem should jump to the other unit; otherwise it sounds like the InterLink is the problem.
Last post July 22, 2009, 05:12:35 PM
Last post June 24, 2011, 10:12:16 AM
Last post July 03, 2012, 09:41:27 PM
by bomac
Last post December 20, 2012, 02:39:09 PM
Last post February 15, 2013, 05:29:41 AM
by nicko_cairns
Last post April 04, 2014, 11:34:17 PM
Last post August 07, 2014, 08:07:28 PM
by CamoHunter
Last post July 07, 2015, 07:52:53 PM
by yahoo
