Author Topic: Manually enter in GPS coordinates to HB 899ci HD SI  (Read 28990 times)
Offline Kauz
  • Unit(s): 899ci HD SI
« on: May 31, 2014, 02:19:32 PM »
how do i convert or enter "NAD83 UTM Zone 15" coordinates into my HB 899? Map Datum is set on "WGS 84" that is the default setting. The position format is set at   dd*mm.mmm'
I have a paper map that i would like to enter the coordinates off of and enter them straight into the 899 if possible.
I sure could use some help with this been trying all day to figure this out.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Manually enter in GPS coordinates to HB 899ci HD SI
« Reply #1 on: May 31, 2014, 11:05:04 PM »
There are several GPS coordinate converters on the web. Here are three links. Hope this helps.
         http://boulter.com/gps/
         http://transition.fcc.gov/mb/audio/bickel/DDDMMSS-decimal.html
         http://www.earthpoint.us/convert.aspx
             Mike
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #2 on: May 31, 2014, 11:34:06 PM »
Yessir!
Good job Mike - that's the best way.
Offline Kauz
« Reply #3 on: June 01, 2014, 11:23:19 PM »
Thanks for the info on the links your help is appreciated!!!
 I did find another link that i used but i did have to register on the website and they do charge .10 cents for each time you do a coordinates conversion. It is very easy to use and it seems to be right on the mark. Here is the link to the website if anybody is interested and they do give 5 free ones so you can try it.  http://legallandconverter.com/
Offline sfw1960
« Reply #4 on: June 02, 2014, 03:40:55 AM »
Free is good! ;)
Last post January 22, 2012, 09:18:22 PM
by Fish Pirate
Last post April 06, 2012, 04:33:37 PM
Last post November 12, 2012, 01:07:27 PM
Last post December 06, 2012, 11:41:23 AM
Last post January 15, 2014, 09:09:43 PM
by LittleGazoo
Last post February 07, 2014, 02:36:26 PM
by Shane23ss
Last post April 02, 2019, 06:47:59 PM
by gpscharts
Last post July 05, 2016, 10:24:17 PM
by coldsteel
