Author Topic: 1198 and 1158 trouble with navionics platinum north card  (Read 20528 times)
Offline prov275
  • Unit(s): 1198 1158
  • Software: 6.810
  • Accessories: ethernet
« on: May 18, 2014, 09:16:46 PM »
Hey guys this has probally been talked about before but I would like to ask if anyone here has a remedy for this.I have an 1198 and 1158 with the latest downloads they work great but I am having trouble with my navionics platinum north card in both units.When you zoom in you lose data and zoom out you loose data you have to find the happy medium zoom level.And when you scroll around it goes white.Theres a youtube video explaining it better than me.Is there a fix for this software issue with navionics or bird,or am I outta luck.When I say lose data I mean screen goes white.Thanks a lot for any advice.
Derek LaPointe
Re: 1198 and 1158 trouble with navionics platinum north card
« Reply #1 on: May 19, 2014, 12:52:04 PM »
Welcome to the Humminbird Side Imaging Forums Derek.
Could you please conform the software version you have on each unit?
Offline prov275
  • Software: 6.810
« Reply #2 on: May 19, 2014, 07:02:34 PM »
Hey greg I tried attaching the software version screen pics and the attachments wouldn't download maybe to big I don't know.They are 1158 my map version 6.810 and 1198 my sonar 6.740.Iam getting frustrated if its not goona go, i'll fight it at different zoom levels if I have to, spent a lot of money to try and avoid these problems >:(.Thanks again greg.
« Last Edit: May 19, 2014, 07:06:25 PM by prov275 »
« Reply #3 on: May 20, 2014, 10:55:00 AM »
Derek,
Well those are certainly the current software versions for both units.  Is this Platinum map card one of those that can be updated and if so, have you done this recently?
Did the Platinum card ever work right in either of these units?
It is sounding like the data on the map card may have gotten corrupted somehow.
Offline prov275
  • Software: 6.810
« Reply #4 on: May 20, 2014, 11:12:46 AM »
Hey Greg yes the card is 2013 and yes I downloaded freshest data when I bought it last year.Just afraid to spend money on upgrading the card for no fix.I contacted Navionics yesterday and they told me to delete all the community edits and certain files that ended in ucg uk.Did that to to no avail.What do you reccomend downloading freshest data to my Navionics card or go back a download on my 1158?Thanks Derek
Offline prov275
  • Software: 6.810
« Reply #5 on: May 20, 2014, 11:16:34 AM »
Oh and not sure if it ever worked before I got these units late last year and I fish 100 miles from this spot where the maps are white.
« Reply #6 on: May 20, 2014, 11:29:13 AM »
I would try updating the Platinum card again to see if it helps and then contact Navionics if it doesn’t.
You can check the maps from where you are at by zooming out and moving the cursor over to that area and zooming in.
Offline prov275
  • Software: 6.810
« Reply #7 on: May 20, 2014, 11:56:42 AM »
Thanks for all the help Greg I really appreciate it.Ill give the card an update and go from there hope this works.
Derek Lapointe
Offline prov275
  • Software: 6.810
« Reply #8 on: May 22, 2014, 08:53:28 AM »
Hey Greg I checked both my units with an older Navionics premium card in this same area and when I zoom to .25 white screen.scroll around and white screen zoom out I get data zoom in and it comes back.its in this one area of Lake Michigan big bay de noc that I walleye fish all the time.its a problem on your end so what do I do now or just deal with it?
« Reply #9 on: May 22, 2014, 10:46:44 AM »
prov275,
You may want to check with Navionics to see if this area is even covered by those map cards.  I tried searching the lake lists on the Navionics web site for Platinum North and Premium North map cards and only found that they listed Grand River and Sturgeon Bay for Lake Michigan.
Offline prov275
  • Software: 6.810
« Reply #10 on: May 22, 2014, 11:14:08 AM »
No Greg it works just fine just 2 zoom levels don't work .1 nm and .25 nm in this certain area of the bay I can run from garden bay at .25 I get half way thru the bay and it goes white I half to zoom in to .5 or 1000 nm to get my data back.it worked perfect in my lowrances gen 1 hds 10s.
« Reply #11 on: May 22, 2014, 11:29:20 AM »
Oh, I did not understand that it would show if zoomed in closer but just not at those certain zoom distances.  It would be best if you called the Humminbird Customer Resource Center folks and report this so that it can be pushed up chain of command/reporting.  Be sure to state what chart zoom levels it does and does not work at.
Offline prov275
  • Software: 6.810
« Reply #12 on: May 22, 2014, 11:48:48 AM »
Thank you Greg will do.yeah I even tried it on my buddies 958c with a lower software version sounds like every bird will do this at theses zoom levels in this area.thank you again for pointing me in the right direction.
Derek LaPointe
Offline Jay415
  • Unit(s): 1198c SI, 998c SI, 385ci DI
« Reply #13 on: September 20, 2014, 10:18:35 PM »
Sounds like the same issue I have. Which still hasn't been fixed.
http://forums.sideimagingsoft.com/index.php?topic=6863
Offline prov275
  • Software: 6.810
« Reply #14 on: September 21, 2014, 11:57:33 AM »
Yeah I pretty much gave up on this issue.ive called bird 5 times no one will give me a solid answer.Doesnt seem to be to important to them not enough complaints in my area I guess.Nice.
Last post January 02, 2012, 07:57:28 AM
by tommy29461
Last post March 14, 2010, 04:04:19 PM
by George
Last post October 11, 2010, 09:40:47 AM
by George
Last post January 09, 2012, 07:19:04 AM
by George
Last post July 29, 2012, 09:27:39 AM
by George
Last post February 15, 2013, 09:28:31 PM
by crazyaboutcoues
Last post March 27, 2013, 09:28:07 PM
Last post August 26, 2013, 08:52:36 PM
by maachuu
