Author Topic: 1199 CI SI With Yamaha NMEA2K  (Read 13763 times)
Offline tajitrump
  • Unit(s): 899 SI
  • Accessories: 5 Port Switch
« on: May 17, 2014, 09:12:34 PM »
Finally got my 1199 linked up to my 2007 200 HP HPDI.
Problem is that the only data coming to the 1199 is the RPM and temperature.
Signal comes through a harness connected to the Command port on the motor into a NMEA2K network, then to a Humminbird ETH NMEA2K connector, then to a Humminbird 5-Port Ethernet box, then to the 1199.
Any help on this would be greatly appreciated!
Offline viper200
  • Unit(s): 998,1199,360
  • Software: 7.090,7.020,2.030
  • Accessories: NMEA2K,Ethernet
Re: 1199 CI SI With Yamaha NMEA2K
« Reply #1 on: June 06, 2014, 10:34:27 AM »
Need to know what else your looking for if it is speed and MPG you will need a NMEA2K antenna.
Offline tajitrump
  • Unit(s): 899 SI
« Reply #2 on: August 24, 2014, 07:40:30 AM »
Just getting engine hours would be great.
Offline viper200
« Reply #3 on: August 24, 2014, 11:50:28 AM »
Ok what do you have as  your set up now. I am using the Ethernet,NMEA2K modules along with the interface for the Yamaha NMEA2K cable and you will need the NMEA2K starter kit to get power to your NMEA2K network. From there you can add any other NMEA2K stuff you want.
Offline tajitrump
  • Unit(s): 899 SI
« Reply #4 on: August 28, 2014, 07:36:18 AM »
Thanks for the response Viper.  I have the NMEA2K network powered up and it did send the RPM and temperature from my Yamaha to my 1199.  Problem is that I wanted to get engine hours and any other available engine data also.
I called Humminbird customer service and they were no help.  It seems like the data is there but just not displaying on the 1199.
Offline viper200
« Reply #5 on: August 28, 2014, 09:09:17 AM »
Ok need make sure you have the NMEA2K Data Box visible and that window is up on the screen. Next go to menu and go to setup then go down to select readouts you will see 9 boxes in the reasout 1 window use the right and left arrows to get to the selection of engine 1 now hit the info/check button go down to engine hours and again hit the arrow button to select it. Once donw exit out to the NMEA2K Data Box and turn on you switch for the motor you do not need to start it just turn it on. Any moe help just ask.  Some of these set are not in the manual.
Last post August 14, 2012, 03:42:17 PM
by jxxaxxy
Last post October 30, 2014, 11:01:08 AM
by viper200
Last post October 25, 2013, 09:29:29 PM
by freezerfiller
Last post July 19, 2014, 04:11:49 AM
by YuK67
Last post July 21, 2016, 12:34:06 PM
by pat.gearhart@icloud.com
Last post August 22, 2016, 02:30:31 PM
Last post July 25, 2017, 08:03:59 AM
Last post March 29, 2023, 07:13:18 AM
by N9Phil
