Author Topic: Humviewer  (Read 11700 times)
Offline hoselrocket
  • Unit(s): 997csi
  • Software: 4.75
  • Accessories: barometer
Humviewer
« on: February 13, 2010, 10:15:57 AM »
Sorry i am such a novice but is humviewer just for recordings or are there applications for screenshots as well?  I have downloaded the program and cannot find any recording that i made on the sd card, it appears that i have only saved screenshots.  Can i measure the height of an object on a screenshot or just on a recording.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: Humviewer
« Reply #1 on: February 13, 2010, 10:34:34 AM »
Sorry i am such a novice but is humviewer just for recordings or are there applications for screenshots as well?  I have downloaded the program and cannot find any recording that i made on the SD card, it appears that i have only saved screenshots.  Can i measure the height of an object on a screenshot or just on a recording.
Hi hoselrocket,
you can view records in Humviewer and create snapshots from there. But you cannot view snapshots which you have made with your unit in Humviewer. Use a regular photo viewer for that.
If you have recorded something while on the water, it will be in the "RECORD" folder on the SD card. Copy the folder and paste it to a place on your PC where you can find it if you want to review the recording in HumViewer.
Go to the "FILE" tab in HumViewer and click on "OPEN". Browse to the place where your record folder is and open it. Then choose the .DAT file and doubleclick it. The file will be opened. This might take a while, depending on how long the recording is. So be patient. After the file is opened just check the "PLAY" box or press "P" on your keyboard.
You can messure length, height and distance in SI and 2D with HumViewer, but not in a snapshot.
Hope this helps
Good luck / Harry
« Last Edit: February 13, 2010, 10:42:36 AM by Jolly Roger »
YES,......
WE SCAN!
Offline hoselrocket
  • Unit(s): 997csi
  • Software: 4.75
Re: Humviewer
« Reply #2 on: February 13, 2010, 12:15:47 PM »
HI
I do not have a record option on the sd card.  Only profile, snapshot and matrix, is this because i have no recordings on the sd card?
thanks
Offline Jolly Roger
  • HB Addicted
Re: Humviewer
« Reply #3 on: February 13, 2010, 12:25:48 PM »
Right hoselrocket.
In this case you don't have any recordings on the SD card.
Snapshot folder: Pictures
Matrix: Navigation Data
Profile: Unit's Data
Regards / Harry
YES,......
WE SCAN!
Re: Humviewer
« Reply #4 on: February 13, 2010, 12:29:02 PM »
If there is no record on thre SD then check to make sure you selected from your menu on the record screen to start recording and then to stop when you have finished.  chuck
Offline Jolly Roger
  • HB Addicted
Re: Humviewer
« Reply #5 on: February 13, 2010, 12:33:55 PM »
Chuck's right.
Here is something Robert posted the other day how to enable snapshot / recordings view:
http://forums.sideimagingsoft.com/index.php?topic=716.0
Hope this helps
Harry
YES,......
WE SCAN!
Last post May 17, 2015, 09:50:10 PM
by Bayou Basser
Last post February 11, 2017, 01:06:15 PM
by Bayou Basser
Last post February 24, 2017, 02:17:22 PM
Last post April 02, 2017, 05:14:41 PM
by rstell47
Last post December 28, 2017, 09:34:29 PM
Last post June 27, 2018, 05:55:06 PM
Last post February 12, 2019, 10:13:38 PM
Last post July 10, 2020, 12:44:01 PM
by navionic
