Author Topic: humviewer  (Read 27627 times)
Offline bobxxx
  • Unit(s): hb798cihd,hb helix9 si di mega,helix7 si
  • Software: 6.61,1.160,1.84
  • Accessories: AS GPS HS
humviewer
« on: January 14, 2019, 06:11:41 PM »
I've used humviewer for years with my hb 798 but I bought 2 helix 9's
and now I cant get humviewer to work.I deleated the b004 files that were sugested
in one post to no avail.
I have the helix mega si di 9"
thanks for any help
humviewer ver 86
Bob
Re: humviewer
« Reply #1 on: January 14, 2019, 09:09:19 PM »
I'm not sure Bob  ...
I would suspect that it may have something to do with MEGA imaging and CHIRP frequencies not being supported by Humviewer  ... Martin (Humviewer creator) has not checked into the forum in a few years now and no one knows how to contact him  ...
I would also suspect that if you set your HELIX to fixed frequencies by turning all CHIRP off - then Humviewer may work with your recordings  ...
Offline Rüdiger
Re: humviewer
« Reply #2 on: January 15, 2019, 04:42:33 AM »
83/5000
Hi Bob
There are several alternative softwares:
DeepView
SiView
Yellofin
mvh
Rüdiger
Finding is better than losing
Offline bobxxx
Re: humviewer
« Reply #3 on: January 16, 2019, 09:31:02 AM »
I turned chirp off and turned on 455 hz. Still same..I did use a simulated recording .maybe that's not the same
Re: humviewer
« Reply #4 on: January 16, 2019, 08:27:45 PM »
I'm not sure if I've ever tried loading a recording of the simulator into Humviewer  ...
Try a recording on the water with all CHIRP turned off  ...
Rickie.
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Software: Latest Versions
Re: humviewer
« Reply #5 on: February 12, 2019, 05:15:04 PM »
Here’s how I solve this issue. Say I have a recording R00001. If I go into the R00001 folder I will see the various files.  I simply create a sub-folder called B004 and I move all of the B004 files there.  Humviewer will work just fine.
Re: humviewer
« Reply #6 on: February 12, 2019, 10:13:38 PM »
Well this is interesting for sure  ....
Last post May 08, 2012, 09:56:44 AM
by Moose1am
Last post March 03, 2013, 05:11:28 PM
by Rickard
Last post April 28, 2013, 08:50:59 AM
by Ken L
Last post August 21, 2013, 12:30:19 PM
by anglerscode
Last post November 07, 2013, 06:59:58 AM
by palajam
Last post March 24, 2014, 01:21:33 AM
Humviewer ?
Started by Arby2 HumViewer
Last post June 08, 2014, 10:00:06 AM
Last post July 02, 2014, 09:12:22 PM
by crappie60
