Author Topic: HORIZONTAL TRANDUCER MOUNT FOR A 999/998 TRANSDUCER  (Read 16729 times)
Offline bassmasterG13
  • Unit(s): 999ci hd si combo
« on: May 09, 2014, 08:48:04 PM »
I WANT TO MOUNT MY TRANDUCER FOR A 999 BELOW MY TRANSOM IN FRONT OF THE STEP TRANSOM HORIZONTALLY. ( WOULD BE LIKE A CEILING MOUNT) SO IT WOULD STICK OUT BEHIND THE MOTOR TRIMMED DOWN. THE MOUNT SUPPLIED DOES NOT LET YOU DO THAT.ANY OTHER MOUNT CONVERSIONS THAT WOULD LET ME DO THIS. THIS FOR A BASSTRACKER WITH THE STEP TRANSOM. I DO HAVE IT INSTALLED NOW ON THE TRANSOM TO THE RIGHT OF THE MOTOR, JUST WANT A OPTION IF POSSIBLE. I THINK THIS MIGHT WORK OUT BETTER. THANKS
Re: HORIZONTAL TRANDUCER MOUNT FOR A 999/998 TRANSDUCER
« Reply #1 on: May 10, 2014, 09:14:34 AM »
IF I MAKE A L BRACKET AND SCREW THE MOUNT TO IT AND THEN SCREW THE OTHER SIDE UP INTO THE STEP TRANSOM BEHIND THE MOTOR.JUST TO THE RIGHT OF THE DRAIN HOLE. ANY SUGGESTIONS. THANKS
« Reply #2 on: May 12, 2014, 11:59:15 AM »
I have not seen any sort of a mount that would hold the HDSi transducer for the 999ci HD Si unit back behind the motor.  Most mount the transducer off to one side of the motor and then trim the motor up when using the Si sonar.
« Reply #3 on: May 12, 2014, 05:55:44 PM »
I was going to try to make a L bracket to attach mount to and put it behind the motor in front of drain holes by screwing up into L bracket(like a cieling mount) so motor can be trimmed down without hitting and then putting high speed transducer to left which would be mounted higher on step. would tranducers be to close to each other and cause interferance or  would this give me better readings for SI and DI at faster speeds. thanks
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #4 on: May 12, 2014, 06:02:08 PM »
If you don't have a problem with debris in the water, then I would just make a mount to lower it more.
« Reply #5 on: May 13, 2014, 09:45:09 AM »
bassmasterG13,
I’m not understanding something here… what type of boat and motor do you have?
Can you post some pictures of your boat’s transom and what it is you are wanting to do?
Where you planning on using some sort of a Y-splitter cable?
« Reply #6 on: May 13, 2014, 10:02:06 PM »
yes i want to use a Y splitter cable. I have the hdsi transducer mounter on the transom to the right of the motor. i was thinking about mounting it under the step infront of the drain plug with an L bracket. would i get better readings this way so i dont have to trim the motor up. the high speed transducer weill go on the step all the way to the left.
« Reply #7 on: May 13, 2014, 10:11:15 PM »
I have a 50hp merc. picture does not show the 999 tranducer the picture was befor the  install. also the humminbird bracket will not fit above the drain hole thats why i wanted to make a L bracket to push it out in front of drain hole and down but still be protected. thanks
Offline LocDown
    • Fishing Videos
« Reply #8 on: May 13, 2014, 10:53:32 PM »
The recommended install location is about where the other transducer is in the picture.
« Reply #9 on: May 13, 2014, 11:01:56 PM »
if i place it there the motor would be in the way of the SI. thats why to the right of the motor i need to trim up so SI works the further away from motor the more the eng would have to be trimmed.if i can put it below transom with L bracket motor can be trimmed all the way down. Greg whats your take on this. thanks
« Reply #10 on: May 14, 2014, 12:51:53 PM »
I think that if you mount the HDSi transducer there that the Si readings will be better but that it will be more likely to be damaged and more likely that it will cause problems with the water flow either into the motor or through the propeller due to an air bubble formed by cavitation at faster boat speeds.  You can’t tell about the cavitation for sure without mounting and testing it in that location.
If it were my boat I would mount the high-speed transducer where it works the best and move the HDSi transducer where it is more protected but as far away from the high-speed transducer as I could get it.  This may mean I would have to trim the motor up when I used the Si sonar.  If you could get the high-speed transducer to mount under that step, it would not block the Si sonar from the HDSi transducer if it was mounted on the step/transom.
« Reply #11 on: May 15, 2014, 06:26:52 PM »
 Greg, If i mount the 999 tranducer on the step very close to the left of the drain hole and use a 1 inch spacer to kick it out past the drain plug where it would be protected. it would almost be to bottom of hull but not under boat. I would not have to trim motor up. the high speed tranducer would be to the far right on the step with the bottom of the tranducer even with bottom of hull on the left side an a little below hull on right side and higher than the si tranducer. can this be a set up that can give be best results?.thanks.
« Reply #12 on: May 16, 2014, 07:56:09 AM »
It may but the HDSi transducer mounted there is less protected and the high speed transducer will block a small portion of the right Si sonar beam, but if you are set on not having to trim up the motor that could be a good option for you.
« Reply #13 on: May 19, 2014, 07:15:09 PM »
Hi Greg I decided to keep my 999 tranducer on transom to right of motor and trim motor up at lower speeds an mount high speed on step to left. the spitter would be AS SIDB Y and which tranducer xnt 920 or xnt 920 t tm. whats the differance. thanks.
Offline LocDown
    • Fishing Videos
« Reply #14 on: May 19, 2014, 08:07:02 PM »
The tm is trolling motor mount
« Reply #15 on: May 19, 2014, 09:31:34 PM »
thanks for all the help
Offline Megabucks461
  • Making a difference one child at a time for 28 years.
  • Unit(s): 788 998
« Reply #16 on: May 25, 2014, 08:06:54 PM »
I am faced with the same problem on a 96 Ranger 461VS. In order to get a clean shot for SI.
The Price of Freedom is Carved in Stone.
« Reply #17 on: May 27, 2014, 01:12:04 AM »
Here's some info that may be of help for Ranger installations...
http://www.bbcboards.net/humminbird-sonar-gps/172974-ranger-boats-installation-images.html
« Reply #18 on: May 27, 2014, 01:14:46 AM »
The XNT 9 20 T has a temp probe.....
The XNT 9 20 does not...
It doesn't matter with the AS SIDB Y cable because the temperature data comes from the temp probe in the HDSI ...(the temp probe in the XNT 9 20 T would not have a wire going to it thru the AS SIDB Y cable)...
(I'm not sure what your "tm" designation is for ....neither of these 2 xducers is for TM mount...TM mount applications designate with a "XTM ------"...)....
« Last Edit: May 27, 2014, 01:22:02 AM by rnvinc »
Last post August 10, 2010, 11:44:44 PM
by Doug Johnston
Last post June 09, 2011, 10:54:04 PM
by Roddy
Last post January 08, 2012, 12:10:24 PM
Last post January 16, 2012, 02:24:13 PM
Last post March 23, 2012, 11:26:00 PM
by NickO
Last post June 01, 2012, 12:07:47 AM
by Brian37075
Last post March 11, 2014, 04:46:31 PM
Last post March 31, 2014, 11:35:56 AM
