Author Topic: Can 2 units share a HDSI transducer  (Read 7082 times)
Offline BrianL
  • BrianL
  • Unit(s): 1198, 798
  • Software: 6.74
  • Accessories: Ethernet
« on: April 28, 2014, 12:35:26 PM »
I have a 1198 and 798.  I have 2 stations for 798 (bow and rear portside).  HDSI 180T connected to 1198.  Compact sidescan connected to bow mount station.  No transducer to rear port station.
I have 3 stations on ethernet running thru 5 port switch.
Will I be able to run 2 units at the same time using the HDSI transducer and see sonar equally on both units?
Thanks, Brian
Re: Can 2 units share a HDSI transducer
« Reply #1 on: April 28, 2014, 03:20:14 PM »
Yes you can Brian, assuming that is a 798ci HD Si model unit and both have updated software in them.  You should be able to share the HDSi sonar data with the 798ci HD Si unit but only the 200/83kHz 2D and 455kHz Si/Di sonar data as the 798ci HD Si unit does not have the programming or circuitry for the 800kHz Si/Di sonar data.
Offline BrianL
  • BrianL
  • Software: 6.74
« Reply #2 on: April 29, 2014, 12:24:56 PM »
Ok, Thanks.
Last post February 10, 2010, 08:03:50 AM
Last post April 27, 2011, 02:15:58 AM
by Roddy
Last post December 07, 2012, 07:52:12 PM
by reddog
Last post December 23, 2012, 03:36:54 PM
by wolfs4evr
Last post January 09, 2013, 02:46:33 PM
Last post October 18, 2013, 07:20:43 PM
by Kokanee
Last post February 25, 2014, 12:13:35 PM
by silvercloud
Last post January 27, 2015, 10:32:43 PM
by Fredfx21
