Author Topic: 898 share transducer with 798  (Read 9486 times)
Offline ChipsXJ
  • Unit(s): 597ci hd di combo
« on: December 21, 2012, 11:49:39 PM »
Can a 798ci HD si use/share the transducer connected to a 898ci HD si if both units are networked using Ethernet system?
Do these 2 units share data/features well? (are they good networkable partners)
« Last Edit: December 22, 2012, 05:08:41 PM by ChipsXJ »
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: 898 share transducer with 798
« Reply #1 on: December 22, 2012, 08:01:29 PM »
I believe you can share most features except map cards.
Offline wolfs4evr
« Reply #2 on: December 23, 2012, 03:36:54 PM »
Works.  You can share everything except map cards.  One item of note.  The 798 unit and TD do not use/have 800mhz.  So when the 898 is using the 798s TD via the ethernet settings you only get 83/200/455.  When the 798 is using the 898s TD again you only get 83/200/455 since the 798 unit isn't capable of the 800 freq.
What I have in my boat.  898 console/stern TD mount and a 798 bow/TM TD mount.
Last post February 10, 2010, 08:03:50 AM
Last post March 19, 2013, 09:01:51 AM
Last post April 18, 2013, 03:27:06 PM
Last post February 17, 2014, 06:07:14 PM
by gmintimidator
Last post April 29, 2014, 12:24:56 PM
by BrianL
Last post October 31, 2014, 08:34:32 PM
Last post December 23, 2020, 10:01:00 PM
Last post February 23, 2022, 08:52:03 AM
by bbheli
