Author Topic: Transducer position on RIB  (Read 8337 times)
Offline Wobby
  • Unit(s): 899ci HD
« on: April 24, 2014, 05:59:16 PM »
Hi
Ive just fitted a 899ci HD to an inflatable RIB with twin motors and I can’t seem to find a position where I don’t get blocking or shadowing form the motors or drain on the left side.  Any suggestions would be welcomed.
wobby
« Last Edit: April 24, 2014, 06:02:03 PM by Wobby »
Re: Transducer position on RIB
« Reply #1 on: April 25, 2014, 10:32:26 AM »
Maybe someone else with a twin powered RIB will see this and comment but I think your options are to either install the HDSi transducer in between the motors and trim both motors up when using the Si/Di sonar or install a second HDSi transducer on the opposite side of the transom and use an ASA-Si-LR-Y cable to connect them both to the 899ci HD Si unit.
Offline Wobby
  • Unit(s): 899ci HD
« Reply #2 on: April 25, 2014, 07:59:33 PM »
Thanks Greg
I had considered mounting it between but wasn't sure, trimming the motors up while scanning should not be a problem.
Ill give it a try.
thanks
wobby
Offline wolfman111471
  • All day long
  • Unit(s): 798ci SI HD,
  • Software: 6.250
« Reply #3 on: April 28, 2014, 10:08:35 PM »
PVC board from lowes or Home Depot is very usefull for mounting on hull so moving transducer only puts new holes in the board not your hull. Just cut board to conform to bottom of hull contour then permanently mount to hull in area
Fishing is priceless , bk big fish $4.00
Offline Wobby
  • Unit(s): 899ci HD
« Reply #4 on: April 29, 2014, 06:03:19 AM »
Thanks,
 Thats a good idea but Ive allready mounted it between the motors and will give it test .
wobby
Offline Wobby
  • Unit(s): 899ci HD
« Reply #5 on: May 21, 2014, 12:55:46 AM »
Hi
Tried out the transducer position between the motors and its working well, no difference with motors trimmed up or down.
Thanks for the help.
wobby
Last post December 23, 2010, 09:23:09 AM
Last post February 03, 2012, 04:26:18 PM
Last post February 15, 2012, 11:28:03 AM
Last post September 08, 2013, 06:57:45 PM
by N9Phil
Last post November 15, 2013, 03:26:01 PM
Last post May 27, 2014, 12:34:10 AM
Last post May 08, 2017, 10:32:00 AM
by Tbonk81
Last post December 03, 2017, 09:07:29 AM
