Author Topic: 899 SI problems  (Read 9888 times)
Offline jspencer1207
  • Unit(s): 899ci
899 SI problems
« on: April 22, 2014, 05:06:23 PM »
I purchased my 899 in February and was disappointed in the fact that it came with the compact transducer. I just recently upgraded to the HDSI transducer so i could use it at 800kHz. Well i am still disappointed because there is no difference. 455kHz looks good but when i turn it to 800kHz it is very bleached out. I have seen some other posts about this problem so has anyone figured out if it a software problem and if it is being fixed?
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
Re: 899 SI problems
« Reply #1 on: April 23, 2014, 06:00:47 AM »
Have read about this many times but have not heard of a fix yet.  As I'm sure you have read as well it has something to do with the update or what you are running now.  Hope you and others get a fix soon. good luck
Tell them I've gone fishing!
Re: 899 SI problems
« Reply #2 on: April 23, 2014, 11:36:23 AM »
Humminbird Engineering is still working on this.
Offline Saltykayak
Re: 899 SI problems
« Reply #3 on: April 23, 2014, 03:25:13 PM »
I have been out about 10 times with my new 899 with the HD transducer. Although I am inexperienced with side scan (this is my first) I have used ONLY the 800 kz setting and have not seen a problem once the contrast/sensitivity is adjusted.
I am in salt water also.
Here is a captured shot from Humviewer of a sunken boat.
I normally 'invert' the color (make negative) as I think it shows more detail...ila_rendered
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
Re: 899 SI problems
« Reply #4 on: April 24, 2014, 12:18:47 AM »
Agree on the detail Salty
I run 455 mostly, only change to 800 in deeper water.  I have found myself using 800 in say 15-20 FOW to get better detail on structure but other than that the 455 does what I need.  Granted, I'm running a 898 with 6.4.  I never seen a reason to change anything due to what I was getting from the unit and hearing of others woos.  The  advice I got her when I first started out laid a foundation to seeing better images and now I'm happy.
Salty, in salt water with all that sand do you find that you have to run a little higher in your Sen. than most speak of for a harder bottom?
Last post March 18, 2011, 09:02:06 AM
by maxflia
Last post April 26, 2011, 06:41:14 PM
by TazzMan
Last post January 13, 2012, 02:42:44 PM
Last post July 19, 2012, 11:46:55 AM
Last post February 05, 2013, 12:44:46 PM
by whitefish
Last post June 18, 2013, 03:14:59 PM
Last post July 02, 2013, 11:54:13 PM
by shwayne
Last post January 04, 2016, 10:19:13 PM
