Author Topic: 999 and 1199 switch between console & bow  (Read 6433 times)
Offline rpro
  • Unit(s): 999ci HD SI, 1199ci HD SI
  • Software: 7.02
  • Accessories: AS ETH 5PXG, AS ETH NMEA2K
« on: April 15, 2014, 09:55:30 AM »
I've got a new 1875 Lund Crossover that is about to be rigged with a new 999 and 1199. My plan is to have the 1199 mounted at the bow so I can see it easier since eyes are further from the locator at that position, and the 999 at the console on the top RH side of the dash on a Ram mount, thinking that the 1999 would be much more difficult to see past if it were located there since this is at eye level.
If I decide at some point that I want to try switching these two units around just to see how I like it, is it relatively easy from a wiring standpoint? Am I correct in thinking that the number and type of wires are the same, but just the "quick" connectors on the backs that gather the wires is different? If this is the case, I could just spend 10 or 15 minutes switching these connectors around, is that correct? (Both locators lead to the five port switch via ethernet.)
Re: 999 and 1199 switch between console & bow
« Reply #1 on: April 15, 2014, 11:02:21 AM »
You are correct on the cables and connector collectors rpro.
Both units also use a different gimbal mount as well.
Last post October 28, 2013, 04:30:27 AM
by Nitro78
Last post March 04, 2014, 07:37:50 PM
by Dieago
Last post September 19, 2014, 09:57:28 AM
Last post July 01, 2014, 02:12:18 AM
by Nitro78
Last post March 11, 2014, 10:56:58 AM
Last post March 17, 2014, 11:56:17 AM
Last post March 27, 2014, 02:03:08 PM
by rpro
Last post July 28, 2014, 12:16:00 PM
by Kevin Kromrey
