Author Topic: Flat Bottom SI Problems  (Read 5765 times)
Offline OutdoorsmanDirect
  • Unit(s): 1198, 899, 798
  • Accessories: kylemitchellnicholas
« on: March 21, 2014, 08:37:20 AM »
Hey Guys,
I recently installed a 899 CI SI on my flat bottom river boat. Like I have on my other boats, I installed the transducer 15" outside of the diameter of the outboard or 21" from center. When I went to test the unit, I'm getting what looks like block out from the skeg &/OR prop.
I know I can install a second transducer to the left of the motor, and if it is blockage, that should fix it.
I wanted to know if anyone has had this happen, and is so, did you have any luck in moving the transducer? If so which direction... I was reading where some users fixed this by moving closer to the outboard about 17" from center.
Thanks!
Re: Flat Bottom SI Problems
« Reply #1 on: March 21, 2014, 11:14:43 AM »
In case anyone is waiting for me to reply to this message: I already replied to his direct e-mail on this but please post your recomendations anyways.
« Reply #2 on: March 22, 2014, 01:46:24 AM »
Blockage "usually" shows at the same distance from the center line all the way thru the SI history...
(Your left SI history is inconsistent)...
Were you trimming your motor up while he left SI was showing less blockage and then suddenly trimmed the motor back down...??
Last post October 12, 2009, 11:16:21 AM
by FriscoSpices.Com
Last post March 04, 2011, 12:43:01 PM
Last post November 12, 2011, 07:30:24 PM
Last post October 10, 2014, 09:08:50 AM
Last post February 07, 2013, 08:44:05 AM
by gixxer01
Last post April 30, 2013, 01:07:01 AM
Last post December 12, 2013, 10:09:04 PM
by godwinrl@hughes.net
Last post May 28, 2025, 01:43:18 PM
by Kenai
