Author Topic: 998 bottom readings at speed.  (Read 9445 times)
Offline godwinrl@hughes.net
  • Unit(s): 997SI, 2 ea 788
  • Software: 4.750
« on: December 11, 2013, 03:20:41 PM »
I have a 998 HD SI mounted on a Basscat Cougar.  Also in dash is mounted a Hum. 787 c.  Is it possible to join these two to one transducer that I can use to read the bottom at speed.  I know that I can install a XP 9-20 transducer and use the Y-cable (AS SIDBY) to the 988 for it to read speed and use the SI transducer for other functions.  The reason I am asking about connecting the two ( 787, 988) is that my 787 transducer has stopped working.  Thanks, Roger Godwin.
Re: 998 bottom readings at speed.
« Reply #1 on: December 12, 2013, 01:20:03 PM »
You could by way of a US3 Unit Switch but you would have to remember to toggle the switch when you want to use the 787 unit and back again for the 998 unit.
  • Software: 4.750
« Reply #2 on: December 12, 2013, 10:09:04 PM »
Thanks, I thought that would be the only way.  I'll probably just order a transducer for the 787 and the others  for the 998 and install both.
Last post December 31, 2010, 03:58:22 AM
Last post November 14, 2012, 03:09:53 PM
by RivRunR
Last post September 01, 2012, 11:24:57 AM
Last post July 29, 2013, 01:07:56 PM
Last post December 06, 2013, 08:07:02 PM
by JDX
Last post September 09, 2014, 10:33:01 AM
Last post May 09, 2015, 10:09:46 PM
Last post March 25, 2021, 12:26:27 AM
by fishreed
