Author Topic: Compatable Transducer for 998cSI  (Read 7348 times)
Offline cache22
  • Unit(s): 998c SI
  • Software: 6.74
« on: February 26, 2014, 12:22:45 PM »
I have an older 778ci with a xnt9 20 t transducer.  I wish to connect this TD through a TS3 W switch to my 998 for high speed operation (will abandon the 778); however, I don't see the 998SI listed on the XNT9 20 compatability list. My question is rather this TD can be safely used with the 998?
« Last Edit: February 26, 2014, 12:24:03 PM by cache22 »
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Compatable Transducer for 998cSI
« Reply #1 on: February 26, 2014, 01:36:29 PM »
You will not get temperature but will work for dual beam.
« Reply #2 on: February 26, 2014, 02:40:32 PM »
Welcome to the Humminbird Side Imaging Forums cache22.
Yes, either the XNT-9-20 or XNT-9-20-T (you stated both models) can be used with your 998 unit.  If this is the non-“T” version it will be as bobcoy stated and you will not have water temp when switched to the XNT-9-20 transducer.
Offline cache22
  • Unit(s): 998c SI
  • Software: 6.74
« Reply #3 on: February 26, 2014, 03:15:14 PM »
Thanks Fellas...... just wanted to be sure before making the switch.
Last post March 01, 2012, 04:23:29 PM
Last post March 15, 2012, 02:58:10 PM
Last post April 25, 2012, 01:08:15 AM
Last post April 11, 2013, 03:23:26 PM
Last post June 18, 2013, 12:44:31 PM
Last post August 12, 2013, 06:53:27 AM
by Gillfisher
Last post October 15, 2016, 07:59:42 PM
Last post November 30, 2018, 01:21:14 AM
by FishinLite
