Author Topic: is piranha max 20 tranducer compatable to use on 798 hd si  (Read 7788 times)
Offline crappiejigger
  • Unit(s): pirahna max 20; 798si
« on: April 10, 2013, 02:45:33 PM »
was thinking of trying to use my 798 both in the front and back of boat with the si tranducer in the back. then try and use old piranha max 20 trans. up front. (tranducer XHS-9-20-T)
it has built in temp and is 20 deg. and 60 deg. coverage. wondering if it would work ????
Re: is piranha max 20 tranducer compatable to use on 798 hd si
« Reply #1 on: April 10, 2013, 04:20:51 PM »
It will work but you will not get any Si or Di sonar readings from it.
Be sure to change the Transducer Select menu setting when you connect it to this transducer.  Depending on the software version you are using you will have to use the “Dual Beam” or “Quad Beam” menu setting.
« Reply #2 on: April 10, 2013, 09:05:03 PM »
thanks very much greg for the quick reply. thats great that it will work,but i knew the si and di wouldn't work with transducer. I figured id use the si and di while motoring around then move head unit up front to fish. now i just need another head mount for front.
« Reply #3 on: April 11, 2013, 03:23:26 PM »
Make sure that you get the one for the 700E series units crappiejigger.  It’s the MS-700E
http://store.humminbird.com/products/411813/MS_700E
(shop around for better pricing).
Last post July 15, 2010, 06:11:34 PM
Last post March 22, 2012, 08:15:32 PM
by Troutcatcher
Last post July 11, 2013, 09:35:34 AM
Last post February 26, 2014, 03:15:14 PM
by cache22
Last post March 16, 2014, 09:29:58 PM
Last post April 16, 2014, 05:03:00 AM
by garm
Last post October 15, 2016, 07:59:42 PM
Last post November 30, 2018, 01:21:14 AM
by FishinLite
