Author Topic: Transducer location  (Read 11505 times)
Offline Catfish Capone
  • Unit(s): 998c HD SI & 570 DI
  • Software: Factory
Transducer location
« on: February 18, 2014, 04:56:25 PM »
Hey guys, getting ready to install my new unit, 998c HD SI, looking for feedback on where I should mount my transducer.  I included a some photos of my transom.  Thanks!
« Last Edit: February 18, 2014, 05:03:09 PM by Catfish Capone »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Transducer location
« Reply #1 on: February 18, 2014, 08:45:17 PM »
My first choice would be to the left of the tie down strap, equal distance between the two strakes. (in photo 2)
At the current transducer location, I think the turbulence at the corner may create problems.
Wait for other feedback before you start drilling holes.
Offline Planokeith
  • Unit(s): Helix 12 MEGA SI Gn2, Helix 7 CHIRP Gps
  • Software: 1.61 , 1.65
« Reply #2 on: February 28, 2014, 09:43:02 AM »
I would mount it in the center .At the current position, the motor will interfere with  side scan  :)
« Reply #3 on: February 28, 2014, 02:12:31 PM »
I agree with Newkid about the turbulence on the right side.
I'd move it to the left, about 1/2" from the right side of
the strap.  That way, the motor won't cause any turbulence.
I think it would be far enough away from the right strake.
With your motor down, in normal running position, as long as the
transducer has a clear line of sight to both sides of the boat,
then your SI should work just fine.
Go to the back of your boat and look at the line of where your transducer is installed.  If you can see anything physically blocking that line on dry land, then it will also be blocking the signals on the water.
Hey Catfish, you might want to throw a little paint on your
trailer, and a propeller on your motor.  Just sayin. :)
« Last Edit: February 28, 2014, 02:14:23 PM by ITGEEK »
  • Software: Factory
« Reply #4 on: March 02, 2014, 11:12:30 PM »
Got new prop!  Paint cost money, money buys catfish hooks.  Hooks<Paint!
Offline Rotus623
  • Software: 6.49
« Reply #5 on: March 02, 2014, 11:51:14 PM »
Thats that good ole catfish philosophy 101!
Last post March 16, 2011, 11:53:13 AM
by blake711
Last post March 25, 2016, 05:56:45 PM
by fishreed
Last post April 06, 2016, 08:43:34 AM
by jabsy
Last post April 04, 2016, 10:15:28 PM
Last post April 18, 2016, 11:34:34 PM
Last post February 04, 2017, 02:34:58 PM
Last post May 14, 2017, 11:15:29 AM
by Dieago
Last post May 03, 2017, 08:47:39 AM
