Author Topic: 798 gps issue  (Read 11188 times)
Offline frenzyfisher
  • Unit(s): 789ci HD SI
798 gps issue
« on: February 09, 2014, 04:43:20 AM »
Guys turned on the gps view all I see is brown with blue lines when moving around and compass view. How do I get the lake view instead of this?
Offline DCottrell
  • Unit(s): 798ci HD SI
  • Software: 6.250
Re: 798 gps issue
« Reply #1 on: February 09, 2014, 01:10:56 PM »
You should be able to cycle through the different views by pressing the view or exit button.
David Cottrell
Re: 798 gps issue
« Reply #2 on: February 15, 2014, 09:01:24 AM »
tried the view and exit key all I see is brown screen and blue lines where my boat has gone
Re: 798 gps issue
« Reply #3 on: February 15, 2014, 11:01:05 AM »
Are you able to Zoom in and Zoom out with the + and - buttons...??
Re: 798 gps issue
« Reply #4 on: February 15, 2014, 01:28:54 PM »
Yes I am able to zoom in and out but it only makes the path of the boat larger. I just can't see the body of water it has to be on the map it is Fayette lake in Las Grange Texas
Offline ezfishn
Re: 798 gps issue
« Reply #5 on: February 15, 2014, 04:56:57 PM »
are you using a map card?  Just checked and don't believe that lake is covered under the contourxd maps that are preloaded on the units from Humminbird.  You would need to buy a Navionics or Lakemaster map card that covers your preferred lakes.
« Last Edit: February 15, 2014, 05:01:40 PM by ezfishn »
Re: 798 gps issue
« Reply #6 on: February 15, 2014, 06:47:10 PM »
That is it, no I am only using preloaded software that has to be it
Re: 798 gps issue
« Reply #7 on: February 17, 2014, 08:38:46 PM »
Is there a list on the net of preloaded lakes in Texas ?
Re: 798 gps issue
« Reply #8 on: February 17, 2014, 08:58:55 PM »
Last post January 02, 2010, 08:37:04 AM
by soretoe
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post April 26, 2012, 09:36:12 AM
Last post July 05, 2014, 03:01:49 PM
by mike1957
Last post July 07, 2014, 07:46:42 AM
by Sawyer
Last post August 09, 2014, 04:47:06 AM
Last post December 01, 2014, 10:06:07 PM
Last post December 29, 2015, 12:04:30 AM
