Author Topic: 6.180 issue  (Read 9689 times)
Offline boec0020
  • Unit(s): 958c
  • Software: 6.180
6.180 issue
« on: April 22, 2012, 06:24:12 PM »
I recently updated by 958c to version 6.180 and ever since, my GPS stopped working.
On the GPS Diagnostic view, the screen flashes and it drops all of the satellites and then it blinks again and it locks on a signal. It does this in sequence.
Anyone have this issue with the new update? Is there any chance I can remove the update? Thanks
Re: 6.180 issue
« Reply #1 on: April 22, 2012, 06:30:00 PM »
The 6.180 has problems with several of the units.
You could download a previous version and see if that fixes the problem.
I just noticed we dont have any code for the 958 on the forum.
Do you have anything else connected to the 958?
Offline boec0020
  • Unit(s): 958c
  • Software: 6.180
Re: 6.180 issue
« Reply #2 on: April 22, 2012, 07:02:29 PM »
The 958 is not connected to anything.
Can I remove the update? Does resting the unit to factory default settings do this?
Re: 6.180 issue
« Reply #3 on: April 22, 2012, 07:06:58 PM »
You cannot remove the update per se.
However you can install a previous code and that will replace the current loaded code.
It is suggested that you restore factory defaults prior to and immediately after a code change.
Newer code is supposed to do that for you but it may be wise to do it anyway manually.
Restore defaults just positions the unit to accept an update and to restore any thing the install may have done that is not normal for the user..
Can you get a previous code?
I am trying to get my hands on the last and the current for this forum. If we can get that then you can download from here..
« Last Edit: April 22, 2012, 07:08:59 PM by sonar2000 »
Offline boec0020
  • Unit(s): 958c
  • Software: 6.180
Re: 6.180 issue
« Reply #4 on: April 25, 2012, 07:56:20 PM »
any luck or do I have to send the unit back to humminbird?
Re: 6.180 issue
« Reply #5 on: April 26, 2012, 09:36:12 AM »
We put a back level for the 1197.  still waiting on a  copy of the back level for the 1198.
You may want to send in to HB.
chuck
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post September 03, 2013, 03:15:54 PM
by exudedude
Last post January 07, 2014, 01:36:48 AM
Last post January 14, 2015, 05:47:02 PM
Last post January 28, 2014, 02:54:02 PM
Last post February 17, 2014, 08:58:55 PM
Last post July 05, 2014, 03:01:49 PM
by mike1957
Last post July 07, 2014, 07:46:42 AM
by Sawyer
