Author Topic: Transducer Insert and Prop Wash Spray  (Read 14014 times)
Offline jerdog
  • Unit(s): 598SI Combo
« on: January 22, 2014, 06:12:00 PM »
Hey Guys,
I just installed a new 598ci SI unit.  It came with a separate package called a Transducer Insert.  What is this for and it is necessary?
Also, when running my boat at a top speed of 25mph I am getting spray coming up off the transducer.  Any suggestions on what is causing this?
Thanks for any and all suggestions!
Re: Transducer Insert and Prop Wash Spray
« Reply #1 on: January 22, 2014, 06:16:24 PM »
The insert it to keep the spray down!  ;D
Offline Vt Rebel
« Reply #2 on: January 30, 2014, 07:49:12 PM »
I have a 898 mounted on my Lund and the water spray is bad.  How do I stop it?  I did not get a insert for my transducer
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #3 on: January 30, 2014, 09:27:28 PM »
Same here on my Lowe with the roster tail.  At first I thought it was due to being to low but in raising it I had problems with not getting clean water under the ducer.  Lowered it and cleared it up.
 Will have to check and see what I need to do in ordering one, done had one bad experience with clipping something in the water.
Tell them I've gone fishing!
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #4 on: January 30, 2014, 09:53:50 PM »
The center item in the top row in this link is what your looking for.
    http://forums.sideimagingsoft.com/index.php?action=media;sa=album;in=13
Some people have had good luck wrapping the bracket with electrical tape where the insert would go.
Cheap fix and worth a try.
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #5 on: January 30, 2014, 10:26:40 PM »
thx Newkid4SI for the link
Does anyone have or can take a px of this already installed?
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #6 on: January 30, 2014, 10:55:32 PM »
A better picture in this link. Fourth row, fourth from left.
  http://forums.sideimagingsoft.com/index.php?action=media;sa=album;in=13;nw;start=25
I think inserted between the plastic ears, front of transducer toward the back, flat end toward boat, curved side up. Just guessing.
If I didn't have a plug, I would try the tape around the plastic ears.
« Last Edit: January 30, 2014, 11:03:10 PM by newkid4si »
« Reply #7 on: January 31, 2014, 09:15:08 AM »
That transducer plug is for the CSi (Compact Side Imaging) XNT-9-Si-180-T transducer only.  There is no such plug for the larger HDSi transducers.
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #8 on: January 31, 2014, 09:24:15 AM »
Bummer, thx greg. you saved me some money.
ooh well looking on the bright side I took some precautions to help if I do tap something again.
Offline Vt Rebel
« Reply #9 on: February 02, 2014, 10:00:20 PM »
Sounds like Humminbird needs to get a fix for our larger transducers!!!  The problem is bad and the answer is not wrapping the bracket with duct tape!  We pay good money for these units and should not have to comprise!
« Reply #10 on: February 03, 2014, 12:59:33 PM »
If this transducer is causing water spray then it is mounted too low on the transom.
Last post July 20, 2016, 05:42:28 PM
by Gmcquire
by Sonshine Fishing
Last post April 05, 2010, 10:52:01 PM
by blharr4400
Last post April 27, 2012, 09:50:51 AM
by steelebob
Last post July 02, 2012, 05:02:07 PM
Last post February 14, 2014, 09:21:29 PM
by Gimp
Last post June 04, 2014, 11:01:14 AM
Last post August 23, 2017, 02:44:04 AM
by cardiovert
