Author Topic: Please help with huge plume of transducer spray  (Read 10477 times)
Offline cardiovert
  • Unit(s): Helix 9 Mega
  • Software: Not sure
  • Accessories: none
« on: August 22, 2017, 12:01:39 PM »
Judging from that ugly spray of water and foam on the port side, near the motor, would you say my transducer is too high or too low?  Its's a Helix 9 mega Transducer.  This probably seems obvious to everyone, but I've never got this before.
Thanks!!
« Last Edit: August 22, 2017, 02:20:57 PM by cardiovert »
Offline mako9man2
  • Unit(s): 999ci HD SI
Re: Please help with huge plume of transducer spray
« Reply #1 on: August 22, 2017, 04:38:18 PM »
Does your Helix read depth when you are on plane?  At WOT?
How fast can you go before you lose the DI or SI image?
Offline cardiovert
  • Accessories: none
« Reply #2 on: August 22, 2017, 04:43:24 PM »
I haven't hooked it up yet.  I'm assuming that the placement is way, way off, judging from that spray.  Any thoughts on whether I should start by raising or lowering the ducer?  I'd like to keep the launching and retrieving of the boat to the minimum times necessary, as I'm moored at a marina for the next few days.
« Last Edit: August 22, 2017, 04:49:12 PM by cardiovert »
Offline mako9man2
« Reply #3 on: August 22, 2017, 07:59:42 PM »
It appears to me that the transducer is too low in the water.
Adjusting transducers can be a pita.  I start by using a straight edge on the bottom of my boat to insure that the bottom of the transducer is riding just slightly below the bottom of the hull.  Potentially as important is the angle of the transducer relative to the angle of the boat at fast idle.  Here is a link to an excellent YouTube video on leveling transducers.  I had no idea how critical this was until I followed the instructions.  https://www.youtube.com/watch?v=JuYsmJRc_fE&t=10s
I have no rooster tail or water plume and my Helix SI/DI transducer reads perfectly at all speeds up to and including WOT at 50+mph.
Offline cardiovert
  • Accessories: none
« Reply #4 on: August 23, 2017, 02:44:04 AM »
That's awesome advice and great place to start!  Thanks for that link. Unfortunately, I didn't use the straight edge because I was in a hurry. I'll take it out and do it with more patience this time. Thanks so much for your help!
by Sonshine Fishing
Last post April 05, 2010, 10:52:01 PM
by blharr4400
by Brian37075
by jgcox6
Last post January 14, 2014, 07:41:46 PM
by Dieago
Last post February 03, 2014, 12:59:33 PM
Last post February 14, 2014, 09:21:29 PM
by Gimp
Last post May 07, 2015, 12:28:07 PM
