Author Topic: 798 ci SI Unit crashes/locks up while recording if I crank the engine.  (Read 8550 times)
Offline C. Corner
  • Unit(s): 798ci SI
I have never had this issue before and don't understand why it is doing this. It only does this while recording.
Re: 798 ci SI Unit crashes/locks up while recording if I crank the engine.
« Reply #1 on: January 05, 2014, 12:55:20 AM »
Sounds like a voltage issue.  Weak battery most likely.  The engine pulls a lot of amps during cranking and the voltage to the unit is probably dropping and causing it to shut down.  When you are recording, the unit needs more power than when its just in normal operation.
Check the battery or isolate the unit from the cranking battery and see what happens.
Offline Dieago
  • Unit(s): 999si
« Reply #2 on: January 05, 2014, 10:42:04 AM »
Ive seen engines do what RG said where all the voltage was used to crank the engine and not enough left to fire the ignition.
I think he is right! Put a meter on the power wire to unit and crank engine I bet voltage drops to less than 9 at meter
Last post January 16, 2012, 01:26:10 PM
Last post August 10, 2011, 01:12:46 PM
Last post April 06, 2012, 03:57:46 PM
Last post May 20, 2012, 10:37:09 AM
by shaggy
Last post August 10, 2012, 12:46:07 PM
by borabora
Last post June 28, 2014, 07:59:26 PM
by bigwave800
Last post June 11, 2017, 08:12:16 PM
by fshndude
Last post September 19, 2017, 12:34:23 AM
by reso
