Author Topic: Is this fish  (Read 16581 times)
Offline hgv
  • Unit(s): 798ci HD SI
  • Software: 6.x
Is this fish
« on: November 13, 2013, 01:55:35 PM »
On the right side of the picture, all the white streaks?
Offline JDX
  • Unit(s): 788 ci 898HD SI 899HD SI
Re: Is this fish
« Reply #1 on: November 13, 2013, 03:20:15 PM »
Im going to say just harder returns,rock,sand gravel, maybe a couple fish mixed in. Curious to see what the pros here say !
Offline hgv
  • Software: 6.x
Re: Is this fish
« Reply #2 on: November 13, 2013, 04:25:08 PM »
Yea that is my issue on side imaging, how to tell a rock from a fish. Hey maybe that is why they did not bite .... they were "rock fish".
And the answer if they did not bite then that must be rocks is not acceptable either, how do you tell if that is a fish or ?????
Offline JDX
Re: Is this fish
« Reply #3 on: November 13, 2013, 06:31:32 PM »
I think how they are positioned in the water column . Suspended fish are pretty easy to identify. counter that with bottom hugging fish brings the ? I would go over that area with your 2D sonar for a better reveal. Also dont forget to record ares like this and view them in HUMVIEWER you will be amazed at what you miss ! We will see soem other comments from the main guys here on this too !
Offline JDX
Re: Is this fish
« Reply #4 on: November 13, 2013, 06:33:16 PM »
I also want to say that your speeds at 1.4 I think if you step it up a notch you will get a better picture. I seem to get the best results at 4mph. Obviously there is no set rule for this.
Re: Is this fish
« Reply #5 on: November 13, 2013, 07:33:16 PM »
I think there are fish on the right side on both sides of the harder bottom hump......don't consider myself an expert though.
Offline hgv
  • Software: 6.x
Re: Is this fish
« Reply #6 on: November 13, 2013, 09:28:37 PM »
What is hummviewer
Re: Is this fish
« Reply #7 on: November 13, 2013, 09:32:07 PM »
Humviewer is a software program for viewing your Humminbird Recordings on your computer.  The resolution is much higher than what is shown on the units or in snapshots.
There is a software section here in the forum, and there are several viewers to look at.
Good Luck,
Re: Is this fish
« Reply #8 on: November 14, 2013, 12:43:40 PM »
I’m going to say fish.
I can’t tell for certain that you were travelling in a straight line when you took this Screen Snapshot or not as there are areas of the bottom that appear stretched as what happens when you turn.  If you didn’t turn than I am pretty certain that they are fish.  Look at the rock on the left side about a third of the way down from the top.  It looks pretty sharp, clear and defined.  Just across from it are some white streaks.  This means that either all of the rocks, tress or whatever they were are either long in shape and just happened to be oriented in that direction or it means that something that reflected sonar moved while being imaged.  Usually these are fish.  There are no shadows for these “fish” which may be due to either their height in the water (far from the bottom) or that the bottom slopes off to the right or the bottom composition changed and is a lot software than the area to the left.  Shadows would have helped in more positively identifying them as fish or something else (as in the case of the rock).
Offline hgv
  • Software: 6.x
Re: Is this fish
« Reply #9 on: November 14, 2013, 12:52:00 PM »
yea I was actually using the trolling motor when I took this shot so there was most likely some back in drift.
Offline skigill
  • Unit(s): 1197c NVB, 798c
Re: Is this fish
« Reply #10 on: November 14, 2013, 02:00:38 PM »
Looks like fish to me!
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Is this fish
« Reply #11 on: November 14, 2013, 10:01:19 PM »
Out of curiosity, is that a launch ramp in the lower left of the image and the shore in the upper left?
          Mike
Re: Is this fish
« Reply #12 on: November 14, 2013, 10:06:10 PM »
          Mike
Looks like it to me
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Is this fish
« Reply #13 on: November 14, 2013, 10:19:24 PM »
If there is current flow ( top to bottom or v/v ) and a soft mud bottom on the right,
that would be what I would expect the image to look like.
Re: Is this fish
« Reply #14 on: November 14, 2013, 10:24:45 PM »
I think you should change your profile name....LOL
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Is this fish
« Reply #15 on: November 14, 2013, 10:33:39 PM »
That name is still accurate. I just spend ALOT of time on here learning from folks like you. Thank you and all the other posters.
             Mike
Last post March 21, 2014, 09:08:28 PM
by slabbacks
Last post May 17, 2015, 08:52:36 PM
Last post July 22, 2014, 08:39:08 AM
Last post September 10, 2014, 12:23:19 PM
Last post October 19, 2014, 08:51:51 PM
Last post November 01, 2014, 05:06:04 PM
by Spd 135
Last post August 19, 2015, 12:28:24 PM
by smallstk
