Author Topic: Edit Menu  (Read 8062 times)
Offline ohmitr
  • Unit(s): 798ci SI
Edit Menu
« on: November 04, 2013, 01:27:10 PM »
I'm in the process of cleaning up my waypoints and have discovered I'm able to delete some of them but others I can't.  I think the problem is there is a "lock" icon present in the lower right of the screen in an info window.  When I can delete a waypoint there is a check mark here instead of a lock.  I have no idea why some waypoints show a lock and others a check mark but if a lock is there now I can't even change it.  Any help would be appreciated.
Re: Edit Menu
« Reply #1 on: November 05, 2013, 08:56:12 AM »
ohmitr,
These waypoints may be a part of a Route.  I’m not at work this week so I don’t have access to a unit to test this with.
What version software are you running in your 798ci Si unit?
Offline ohmitr
  • Unit(s): 798ci SI
Re: Edit Menu
« Reply #2 on: November 05, 2013, 03:08:32 PM »
6.3
Re: Edit Menu
« Reply #3 on: November 07, 2013, 08:59:34 AM »
That lock icon may be to show that the waypoint cannot be shared – not 100% sure though as I am not at work and don’t have a unit to check this with.
Did you happen to check to see if you have any Routes?
Is the unit currently set to navigate to a waypoint or travel a route?
Offline ohmitr
  • Unit(s): 798ci SI
Re: Edit Menu
« Reply #4 on: November 07, 2013, 09:42:32 AM »
I solved my problem another way.  I got everything like I wanted it on the SD card, formatted the Nav data and uploaded from the card.  I had wanted to do this before but couldn't find the format option.  I finally did and everything's good now.  Thanks for the help.
Last post March 26, 2011, 06:17:28 PM
by lcookie
Last post April 28, 2011, 04:00:39 AM
by Rüdiger
Last post August 12, 2012, 10:01:37 PM
by benamen
Last post September 18, 2012, 02:03:48 AM
by loeti
Edit .ht files?
Started by Team CTM General Discussion
Last post March 18, 2014, 04:59:27 PM
by LittleGazoo
Last post December 19, 2013, 08:03:34 AM
by jepik
Last post March 24, 2014, 04:05:17 PM
by Rickard
Last post April 09, 2015, 09:48:13 PM
by kerryd15
