Author Topic: Edit .ht files?  (Read 8171 times)
Team CTM
  • Guest
Edit .ht files?
« on: May 12, 2013, 02:00:29 AM »
When exporting tracks to HumminbirdPC I can se all coordinates and depths of the track, one for each row. But if i would like to edit the track and remove some rows, how do I do that, is it possible?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: Edit .ht files?
« Reply #1 on: March 18, 2014, 04:59:27 PM »
Old post, but found it by accident and unanswered.  So here goes:
Each .HT file is a individual Track.  One .HT file = one track.
Each row of latitude/longitude coordinates is a track-point.
You are wishing to edit a track.
Several program exist that can edit Tracks, some are ExpertGPS & ReefMaster.
I have more experience with RM:
  Just import the track asset, then add the track and create a User Map.
  Then just drag&drop or delete track-points.
  Then write track out to an new Humminbird .HT file.
Use HBPC to display track in Google Earth and use GE to modify the track.
Right-click the track, select properties(and leave Properties Box open), then move or delete track-points.
Save as a .KML file, then use GpsBabel to convert to .GPX, .USR or .HT file.
And there are sure to be more ways. . .
Now if this track is composed of multiple track-segments, then still possible, but complications arise.
« Last Edit: March 18, 2014, 05:01:54 PM by LittleGazoo »
Last post April 28, 2011, 04:00:39 AM
by Rüdiger
Last post September 18, 2012, 02:03:48 AM
by loeti
Edit Menu
Started by ohmitr 798c SI
Last post November 07, 2013, 09:42:32 AM
by ohmitr
Last post September 15, 2014, 02:15:34 PM
by Nitro78
Last post August 03, 2015, 09:13:16 PM
by Beaulieu80
Last post August 03, 2015, 01:30:16 PM
by Beaulieu80
Last post September 30, 2015, 06:55:55 PM
by CamoHunter
Last post September 04, 2016, 06:42:31 PM
