Author Topic: Pulling the puck  (Read 7505 times)
Offline steelebob
  • 1994 TRACKER NITRO 160 and 4 cyl 2017 Yamaha 70 h
  • Unit(s): Helix 2nd gen 10 and 9
  • Accessories: Ulterra
Pulling the puck
« on: October 23, 2013, 06:33:39 AM »
Is there any advantage of taking out the gps puck to use in my home this winter with a battery and the 898 "screen"?
I dream of things that never were, and ask why not?
Re: Pulling the puck
« Reply #1 on: October 23, 2013, 08:07:42 AM »
I can't see any advantage to that at all.
I can see a couple of disadvantages, though:
 You'll have to put it back on your boat at some point.
 You could make the already flimsy connections worse.
« Reply #2 on: October 23, 2013, 11:30:09 AM »
Using the GPS antenna in "Normal" mode in your living room would place the boat icon on the chart....well...in your living room...and not on the water...(because that's where the satillites would recognize where the puck is...if it were able to get a signal inside your house)...
Using your unit in "Forced Simulator" mode in your living room allows use of the chart functions as if you were on the water...ie...scouting, marking waypoints, making planned routes, etc...(head unit, power supply, map card - "if desired" ....is all that is needed for use in the house)...
The physical GPS puck is not needed for this...as ITG mentioned..
You can even make recordings of the "Forced Simulator" to help in learning the recording and playback functions of the unit...(if you have an SD Card in the unit)...
Playing back this recording of the "Forced Simulator" on the unit even allows changing settings during the "playback" views ...to learn how different settings affect different views (2d/SI/DI)...
« Last Edit: October 23, 2013, 11:42:26 AM by rnvinc »
Offline steelebob
« Reply #3 on: October 23, 2013, 02:27:50 PM »
Thanx, that is exactly the answer I needed rnvinc
« Last Edit: October 24, 2013, 12:31:55 PM by steelebob »
Last post September 18, 2012, 04:24:14 AM
by Rüdiger
Last post April 11, 2012, 01:52:02 PM
Last post December 06, 2012, 11:56:16 AM
by Consigliere
Last post December 15, 2012, 12:10:23 PM
by Jim Jack
Last post March 06, 2013, 08:31:16 AM
by TroyBoy30
Last post March 28, 2013, 09:42:50 PM
by MTBob
Last post August 18, 2013, 02:52:58 PM
by maachuu
Last post October 20, 2013, 12:06:03 AM
by jdlandrum2002
