Author Topic: ALL SI Models - GPS puck die mod  (Read 11960 times)
Offline Gattlin
« on: April 09, 2012, 11:41:58 PM »
Model:
ALL SI Models
Suggested Upgrade:
GPS puck die mod
Explanation:
Altering the cast for the gps puck "Upper" :/  base to include a larger hole on one side so the transducer cable can by pass though it.  Lolz after all it's a wish list.
Aka: Skinner
Added in Software Version:
Comments on Update:
« Last Edit: April 09, 2012, 11:48:33 PM by Gattlin »
Just one last cast.
Re: ALL SI Models - GPS puck die mod
« Reply #1 on: April 10, 2012, 10:23:10 AM »
Gattlin,
Can you post a picture of this just so we can be sure of what you are asking?
With just the GPS Receiver by itself: you are talking about the white plastic part that is immediately below the gasket, right?
Offline Gattlin
« Reply #2 on: April 10, 2012, 12:22:17 PM »
 Yes that would be the part Greg and below the the gasket is correct ;D  At the bottom edge opposite from each other are the two exit holes just make one a touch bigger :)
« Last Edit: April 10, 2012, 12:53:25 PM by Gattlin »
Just one last cast.
Offline Gattlin
« Reply #3 on: April 10, 2012, 12:36:10 PM »
Yes that would be the part Greg ;D  At the bottom edge opposite from each other are the two exit holes just make one a touch bigger :)
I tried to insert image from my desktop but had no luck I,m doing something wrong :-\
Just one last cast.
« Reply #4 on: April 10, 2012, 02:22:18 PM »
Image is there now Gattlin and it is the same hole(s) I was thinking that you meant.
« Reply #5 on: April 10, 2012, 07:50:56 PM »
+2   I agree with a second hole.
We have at times wanted a second and had to make it..
thanks for submitting..
chuck
« Reply #6 on: April 11, 2012, 10:37:43 AM »
You guys do realize that you can enlarge the hole yourself in the current design don’t you?  Just flip one of the GPS Receivers over and you will see that you can enlarge the hole with out cutting into the interior of the GPS Receiver itself.
« Reply #7 on: April 11, 2012, 01:52:02 PM »
I dont know if I would enlarge the hole.
I think adding a second hole would not put as much strain on the hole or ring.
Making a hole is simple using a round file. that way you wont slip and drill into something you shouldn't...
chuck
Last post October 14, 2009, 12:09:02 PM
by capttim
Last post April 21, 2010, 10:07:12 AM
Last post February 18, 2012, 10:49:25 PM
by choc_e
Last post March 26, 2012, 05:48:00 PM
Last post August 18, 2012, 01:22:34 PM
by Roddy
Last post August 19, 2012, 12:28:02 AM
Last post February 02, 2013, 10:10:24 PM
by ScottMN
Last post May 19, 2014, 08:39:18 PM
by LocDown
