Author Topic: Mount 898c HD SI Transducer on Terrova Trolling?  (Read 9398 times)
Offline J.Miles
  • Unit(s): 898c HD SI C
« on: October 16, 2013, 10:07:18 AM »
I have recently purchased a 898c HD SI and am about to purchase a Minn Kota Terrova with I-Pilot Link. I need some advice on mounting the transducer on the Terrova, will it work on the Terrova, or, should I just stick with the transom mount? and what hardware would I need to mount it. Any insight into this matter would be appreciated.
Re: Mount 898c HD SI Transducer on Terrova Trolling?
« Reply #1 on: October 16, 2013, 12:37:59 PM »
Yes it can be mounted on the Terrova and it will work there.  You will need to contact Humminbird’s Customer Resource folks about exchanging your transom mount HDSi transducer for a trolling motor mounted one or you can use a 3rd party’s adapter bracket to mount the transducer you have to the trolling motor.
Offline J.Miles
« Reply #2 on: October 16, 2013, 12:48:01 PM »
I did contact HB customer service and the lady told me to order the ADSTM7 Trolling motor bracket, she did not say anything about exchanging transducers. Is there a third party mount that will work with the transducer that came with the 898. Thanks Greg
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #3 on: October 16, 2013, 02:02:41 PM »
Transducer Shield and Saver makes great transducer mounts for transom and trolling motor.  A little $$$$$, but very good.
http://www.transducershieldandsaver.com/home/
Now for mounting you can run the transducer cable down the slot in the Terrova shaft:
http://www.crappie.com/crappie/fishing-electronics-photography/118059-terrova-sonar-transducer-mount.html
Tips 'N Tricks 86: Installing Side Imaging on MinnKota Terrova
Or you can use a coiled air-hose like those from Harbor Freight.
Sorry I couldn't find the web address with pictures.
But you run the transducer cable inside the air-hose, then let the air-hose wrap around the lower part of the Terrova shaft.
You cut the air-hose to a good length.
Offline J.Miles
« Reply #4 on: October 16, 2013, 06:23:30 PM »
Thanks for all the help, I am sure I will have a bunch more questions before this is all installed
Last post July 05, 2010, 02:34:14 PM
by Wayne P.
Last post January 02, 2012, 07:40:33 AM
by tommy29461
Last post January 31, 2012, 08:02:31 AM
Last post February 21, 2012, 11:42:08 PM
by Will
Last post January 14, 2013, 01:12:34 PM
Last post August 20, 2013, 04:08:30 PM
Last post February 27, 2014, 11:47:57 AM
Last post March 17, 2017, 07:47:49 PM
by Boots
