Author Topic: Battery for 798  (Read 9908 times)
Offline OleNørskov
  • Unit(s): 570
  • Accessories: speed and temperature
Battery for 798
« on: September 15, 2013, 12:01:14 PM »
Hi guys,
I am looking for a somewhat smaller battery for my 798. I have been looking at a 7.2 ah but I am curious to know if it is enough for 6-9 hours of fishing?
Thanks in advance. :)
Kind regards Ole
Offline Rickard
Re: Battery for 798
« Reply #1 on: September 15, 2013, 12:21:09 PM »
Hi Ole,
I use a 7.2 ah lead-acid battery for my 981 and it use to be enought for "a whole day" with activities. The 981 is one of the most energy consuming Humminbird models and the 798 needs much less. (http://www.humminbird.com/Faq.aspx?TaxonomyId=94A2903)
Regards,
Rickard
Offline OleNørskov
  • Unit(s): 570
Re: Battery for 798
« Reply #2 on: September 15, 2013, 12:40:02 PM »
Thank you very much! No need to bring a 80ah anymore then :)
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: Battery for 798
« Reply #3 on: September 16, 2013, 12:07:02 PM »
For 9 hour use, consider a 12Ah battery, you will come short with a 7.2Ah
Offline Fishndav
  • Unit(s): 798CI SI, 998C HD SI COMBO
Re: Battery for 798
« Reply #4 on: September 16, 2013, 01:06:17 PM »
I am using a 10ah from batterymart.com that has the same footprint as the 7ah. It fits in my humminbird portable rig perfectly I can fish a long day without a problem. I could not find a 12 ah that fit the same. I also invested in a multi stage charger so I don't cook the battery with a standard wall-wart 1amp charger.  This one has been doing me well. and it was worth the $35 bucks. http://www.geniuschargers.com/shop/G750
fishndav
Offline OleNørskov
  • Unit(s): 570
Re: Battery for 798
« Reply #5 on: September 16, 2013, 02:42:37 PM »
I got a minn Kota charger so I should be good! I will see if I can find a 10ah!
Last post December 22, 2009, 09:12:00 PM
by soretoe
Last post August 03, 2010, 03:23:15 PM
Last post March 06, 2011, 03:53:18 PM
by Doc Stressor
Last post June 24, 2011, 11:26:12 AM
Last post June 10, 2013, 10:55:50 AM
by TroyBoy30
Last post October 15, 2013, 02:27:28 PM
by steelebob
Last post June 06, 2014, 01:27:29 AM
by birda40
Last post July 27, 2014, 05:05:10 AM
by JPWalnuthill
