Author Topic: 899 and battery  (Read 6538 times)
Offline birda40
  • Unit(s): Wide Paramount , 899 ci si hd
899 and battery
« on: May 26, 2014, 09:29:05 AM »
Hi all , wondering what the average time of use with a fully charged battery would be? I have two batterys for my trolling motor and finders. Recharge when back at home, ( everynight ). Everything is running at 12 volts.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: 899 and battery
« Reply #1 on: May 27, 2014, 12:46:27 AM »
The current draw on the 899 will be very small in comparison to the trolling motor.
My new units have a 3 amp fuse and the new MinnKota has a 50 amp breaker.
With two batteries, I doubt you'll have to worry about the depth finder.
          Mike
Re: 899 and battery
« Reply #2 on: May 28, 2014, 08:30:49 AM »
There is no real good way to calculate this either as there are too many unknown variables involved.  The 800 series units pull less than 1 amp (~780mA) per hour but it is not just an easy calculation of having a 20 Amp battery so 20/1 = 20 hours of use.  What you don’t know is the actual capacity of the battery at that time nor at what point the battery cannot provide at least 11 volts (this is about the cut-off voltage for the 899 unit).  Best way to find out is a real world test – just try it!
Offline birda40
Re: 899 and battery
« Reply #3 on: June 06, 2014, 01:27:29 AM »
Just got back from first use, battery life awesome.
Last post December 22, 2009, 09:12:00 PM
by soretoe
Last post August 03, 2010, 03:23:15 PM
Last post March 06, 2011, 03:53:18 PM
by Doc Stressor
Last post June 24, 2011, 11:26:12 AM
Last post June 10, 2013, 10:55:50 AM
by TroyBoy30
Last post September 16, 2013, 02:42:37 PM
by OleNørskov
Last post July 27, 2014, 05:05:10 AM
by JPWalnuthill
Last post December 31, 2014, 11:55:35 AM
