Author Topic: 1197c si software update  (Read 10441 times)
Offline acseatsri
  • Unit(s): 1197c si
  • Software: 6.640
  • Accessories: none
« on: August 25, 2013, 03:43:55 PM »
On the HB support site for my unit, it lists V. 6.640 as the latest update for my older unit. I downloaded it and installed it. Now my temp gage is 25 degrees too cold and the ranges for the GPS switch randomly. Is this the correct update for my unit? I looked at the current updates on this site for my unit and it shows V. 6.600 as the latest available for this unit.
PS- When I have the card with the update on it installed at power up, it asks if I want to perform the update. Is this because the original update didn't complete, or is this just not compatible with this unit even though the HB website shows it's the most current available update for this unit?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: 1197c si software update
« Reply #1 on: August 26, 2013, 11:33:10 AM »
Yes, at this time 6.640 is the latest update for a HB1197.
A 1197 on power-up will ask you if you wish to upgrade, if it detects a SD-card with the upgrade on it.  It is not because a update completed or not.
1197 update procedure was changed.  You should on a running unit, do a Restore Defaults, then insert the Update SD-Card and perform the update.  After the reboot, remove the SD-card and do another Restore Defaults.
HB FAQ:
http://www.humminbird.com/FAQ.aspx?Contentid=1737
HB Video:
How to Update Your Unit Software Using a SD Card
IMHO, the HB 6.640/6.680 software update is more for 360-Imaging/AS-GPS-HS(highspeed directional GPS puck).  I like 6.640 on my 1197.  It worked OK only if Chart-Speed was set a 1 or 2.  Worse 2D I've ever experienced as Chart-Speed increased.  I'm currently on 6.310.
Offline LittleGazoo
  • Software: 3.640
« Reply #2 on: August 27, 2013, 12:20:30 AM »
I thought about this some more.  If the unit is at 6.640 and you leave the 6.640 update SD-card in the unit during power-up, it should inform you that you are already on that level.
Access the Self Test screen to see your running software level:
First: <menu><menu>, select Views Tab, scroll & set Self Test = VISIBILE.
Then: Use View or Exit button to access the Self Test screen.
Last post May 18, 2011, 03:23:12 PM
Last post October 24, 2011, 12:22:24 PM
Last post March 04, 2012, 12:03:58 PM
Last post March 06, 2012, 12:40:03 AM
Last post May 28, 2012, 04:50:02 PM
by Rough House
Last post September 17, 2012, 03:24:07 PM
Last post September 09, 2013, 04:07:10 AM
by prowler650
Last post May 07, 2014, 09:46:05 PM
by salvor6
