Author Topic: 1197c New Update 6.310  (Read 11750 times)
Offline sss_floripa
  • Unit(s): HELIX 10 CHIRP MEGA SI+ GPS G3N
  • Software: 2.110
  • Accessories: AutoChart Pro 2.300
« on: May 22, 2012, 08:04:55 PM »
Version 6.310 available only for 1197c SI
Download Update 6.310 (need to register)
http://www.humminbird.com/Support/
File name: 00a4fb8440224afcada233122a97bf34.bin
Re: 1197c New Update 6.310
« Reply #1 on: May 23, 2012, 07:32:22 PM »
Thanks....I put this in our downloads.
« Last Edit: May 23, 2012, 07:56:27 PM by sonar2000 »
Offline George
  • Software: Always up todate
« Reply #2 on: May 24, 2012, 07:17:41 AM »
I have installed Version 6.310 without any problems now need to get it on the lake to check it out.  To date I have installed every update without any problems (knock on wood).  Also, I immediately changed the name to 976310.bin, this way when I save the files on my harddrive I know what version it is.  The system does not care what the name is as long as the extension is "bin".
George
« Reply #3 on: May 24, 2012, 04:29:42 PM »
You are right George on the name.  We on the forum downloads use the unit type and the release level and the _ character.  It does not matter as long as it ends in bin.
Your suggestion is good in that you will always know the level you are at. And able to keep back levels if needed.
Thanks George.
Offline stratofisher
  • Unit(s): 1197C SI NVB
  • Software: 5.840
« Reply #4 on: May 27, 2012, 11:55:52 PM »
Went out with the new update and everything checked out alright.  Not sure if it was this or the 6.180 that added the navigation pointer arrow, but I really like that feature. Allows you to set up the drift to be on the line you want.  That was key fishing for walleyes with a drift sock.   As far as I can tell everything is working good.  I used my XM weather, Navigation, and all modes of Sonar.   Did not record anything so I can't comment on that feature.  It all seemed to work as advertised.  No slow clicks or anything abnormal.  Did have to play with sensitivity as I was at Stockton lake which is rock bottom and deeper than my normal Smithville home waters.  Overall a positive install.
Offline Rough House
    • Rough House Charters
  • Unit(s): 1198c si / Helix 10
  • Software: latest
« Reply #5 on: May 28, 2012, 11:39:14 AM »
I see that its stated as a 1197 update but is it for the 1198 as well?
Lake Erie Fishing out of Erie, Pa
« Reply #6 on: May 28, 2012, 02:14:01 PM »
That is for the 1197.  The 1198 is still the 6.180 level..
Offline Rough House
  • Software: latest
« Reply #7 on: May 28, 2012, 04:50:02 PM »
ok.  thanks.
Last post May 18, 2011, 03:23:12 PM
Last post October 24, 2011, 12:22:24 PM
Last post March 04, 2012, 12:03:58 PM
Last post September 17, 2012, 03:24:07 PM
Last post January 31, 2013, 11:08:31 AM
Last post May 20, 2013, 07:32:00 AM
by TroyBoy30
Last post August 27, 2013, 12:20:30 AM
by LittleGazoo
Last post September 09, 2013, 04:07:10 AM
by prowler650
