Author Topic: 998c HD SI Internel Memory Storage  (Read 9140 times)
Offline ScottA
  • Unit(s): 998c HD SI, Terrova 55, I-Pilot link
  • Software: 6.680
  • Accessories: Wethersense,GPS
« on: August 23, 2013, 09:31:33 AM »
Here's my problem, I'm using Couture Elite to Plan out some Routes and Waypoints for a Lake, i can create the Routes/Waypoints, in Couture, upload them to Hummingbird PC and send them to a Matrix folder on the 32G SD Card,
(41 Routes consisting of 641 Waypoints(Daylight Routes) no tracks or groups) Put the SD Card in the 998 everything uploads automatically as it should, I then created some night Routes and Waypoints with contour, when i try and load them on the SD Card the HB PC program comes up with an error message telling me the Card is full. If i delete the Daytime stuff , i can then load the nighttime stuff on the card, but when i load the card into the 998 , it indicates the memory is full. I have to delete the Daytime Routes off the 998 before it will let me laod the Nightime Routes.
I'm not anywhere neer the capactys listed for the 998 as far as Routes and Waypoints
Why won't it let me Load more DATA
I wish HB would come up with a users guide for the HB PC, The Help tab tell you how it work but fails to tell you the finer points on using the program.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: 998c HD SI Internel Memory Storage
« Reply #1 on: August 25, 2013, 01:50:57 PM »
Check your waypoints for bad info... escpecially date created info (from humpc)
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #2 on: August 25, 2013, 02:10:56 PM »
+1.
You can also sort waypoints by Lat or Lon in HBPC and check for duplicate waypoints.
Duplicate waypoints are defined by HB as identical name, lat & lon.
Also what software levels are HBPC and the HB units?
Offline LittleGazoo
  • Software: 3.640
« Reply #3 on: August 25, 2013, 02:23:12 PM »
Also:
You might also be interested in the HB Waypoint Management Guide:
http://store.humminbird.cust.shopatron.com/media/document/WMG.pdf
The WMS guide is more useful than the HBPC operation manual on waypoints, routes and tracks.
It is written for WMS "on the unit", but WMS organization is available in HBPC.
"MOVE" on unit is equivalent to CUT&PASTE in HBPC.
"COPY" on unit is equivalent to COPY&PASTE in HBPC.
. . . etc.
And here's a forum post on HBPC/WMS:
http://forums.sideimagingsoft.com/index.php?topic=5472.msg34363#msg34363
If you have HBPC Q's, start a HBPC thread and I will try to answer.
I've "pained my way" thru some HBPC.
But HBPC is very useful software and provides back-up for your unit's navdata.
« Last Edit: August 25, 2013, 02:27:07 PM by LittleGazoo »
Last post December 26, 2009, 07:43:00 PM
Last post July 11, 2012, 02:29:26 PM
by Gattlin
Last post January 17, 2013, 12:03:06 PM
Last post December 26, 2013, 02:10:14 PM
Last post April 13, 2014, 11:01:47 AM
by Goosedwnr
Last post May 30, 2015, 07:18:17 AM
by Wallin8r
Last post June 07, 2018, 06:07:21 AM
by tailortom
Last post June 07, 2018, 06:13:23 AM
by tailortom
